Side View Mirror(s) ?
Old 10-15-2015, 08:13 PM
J.Williams's Avatar
J.Williams
J.Williams is offline
Just wondering when side view mirrors became a standard option on trucks. Guy says he had a '77 f-100 without side view mirrors from factory, and sounds odd to me. I figured atleast a side view mirror came on the drivers side, but wasnt sure. Thanks
Old 10-15-2015, 09:56 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
ND will chime in with the "what year" answer. Here are some options to look at till then.
I have had a 73 with type 5's. And I have a 77, 78, and a 79 with type 9's.
Old 10-16-2015, 12:15 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1967 was the first year that a left hand outside mirror was standard equipment for F100/350's (except Camper Specials).
Thru 1972 it was the same plain jane el cheapo non remote mirror as used on 1967/72 Galaxie/LTD and etc: C7AZ-17696-A was placed inside the cab at final assembly.
But the dealers installed all the outside mirrors, and since most people didn't want this el cheapo passenger car mirror, 10's of 1,000's were thrown away by the dealers.
Right & Left Western Junior Mirrors were part of the Camper Special package beginning in 1965.
Beginning 1973, TYPE 5 mirror was standard equipment. Same scenario as 1967/72, dealers installed all the outside mirrors, TYPE 5 "was low mirror on the totem pole" as most people didn't want it.
Old 10-16-2015, 02:39 AM
privateer, eh's Avatar
privateer, eh
privateer, eh is online now
Iv'e got some 2's, 3's and 12's breeding in the parts shed.
Old 10-16-2015, 11:38 AM
JUSTICE1736's Avatar
JUSTICE1736
JUSTICE1736 is offline
not to hijack the thread but how hard is it to go from the type 5 mirror to a roduction type 9? I hate the dinky little mirrors they arnt good for much other than low wind resistance.
Old 10-16-2015, 11:42 AM
NumberDummy
You can install TYPE 9 mirrors...if you can find them, as they're obsolete. 1973/79: There were FIVE different types.
You'll have to fill in the two screw holes for the 'passenger type' mirrors.
Old 10-16-2015, 12:08 PM
bkaul's Avatar
bkaul
bkaul is offline
The type 9 mirrors are also reproduced, e.g.
1973-1979 Ford Bronco and F Series Truck Door Mirror, Support and Head-Broncograveyard.com
http://lmctruck.com/icatalog/fc/full.aspx?Page=95
You'd have to drill new holes and patch the old ones, as Bill said. They install with carriage bolts from the outside and nuts inside the door.
Old 10-16-2015, 12:14 PM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
Bill, aren't 80-96 truck mirrors similar to type 5?
Old 10-16-2015, 12:15 PM
77&79F250's Avatar
77&79F250
X2 on what Bill said. Simple unscrew the type 5 mirrors and locate and install a set of type 9's. FYI I have seen them on ebay and some folks here on FTE have spare sets.
I bet if you run a WTB add in the classified section on here, you will get a set.
Normally the type 9 mount with a 2 bolts (2 top, 2 bottom) and a insert that stays in the door skin. Or just carefully remove the door panel and you can nut and bolt them on. Also they have a thin black plastic gasket under each mount plate.
And yes you will have 2 small holes to plug and 4 new holes to drill.
Side View Manual Mirrors Stainless Steel Pair SET FOR Ford F Series Pickup Truck | eBay
Not exactly correct, look more like a 80's mount plate, but close. On the correct period mirrors, the lower mounts tabs mount above the dent, not below.
Maybe Scott still has his? https://www.ford-trucks.com/forums/1...9-mirrors.html
Old 10-16-2015, 01:11 PM
NumberDummy
Guess who will list the part number and the sources.
There are 5 DIFFERENT types of TYPE 9! D4TZ-17696-A / D6TZ-17696-A / D7TZ-17682-A / D8TZ-17682-A / D9TZ-17682-A
1973-1979 Ford Bronco and F Series Truck Door Mirror, Support and Head-Broncograveyard.com = Specs match D4TZ-17696-A
I tipped Scott that there were some for sale on ebay cheap. (sigh) He bought all 33 of them: D4TZ-17696-A
The span between the brackets is different between D4TZ-17696-A & D6TZ-17696-A
The upper and lower mounting brackets on D4TZ-17696-A are curved, they're flat on D6TZ-17696-A. The mirror heads are the same for both: D4TZ-17723-A
The span of D7TZ-17682-A is different than D4TZ-17696-A & D6TZ-17696-A, but the mirror head is the same.
D8TZ-17682-A has a larger mirror head, there's no gasket between the glass and the head.
D9TZ-17682-A (replaced D8TZ-17682-E) has a larger mirror head, uses a gasket between the glass and the head.
And, there are 3 different Econoline versions, but will not fit F100/350's and Bronco's correctly as the door counter is different.
Old 10-16-2015, 08:30 PM
Riskit's Avatar
Riskit
Riskit is offline
Can anyone help me remove the Bung&Plug that held my (type7) mirrors to the door? I just removed the mirrors and can't seem to get the plug they screwed into out of the door itself.
Maybe I'm over thinking it but once the mirror is removed you can see a alan key fitting. If i turn it the whole bung&plug turn as well.
im lowering my 73/250 and the mirrors I had just didn't work. I will be selling the 7's if anyone needs a nice set..
Any help please
thanks
Old 10-17-2015, 05:19 AM
NumberDummy
Any help please
thanks
Upper pic:
Old 10-17-2015, 06:17 AM
Riskit's Avatar
Riskit
Riskit is offline
Upper pic:
Hello and thanks for the picture. That's is the correct mirror I have and it shows the Pung (I think that's what it's called) that goes into the door and the bolts to the mirror screw into it...
My question, how do I remove that thing? If I put the alan key in the outside it just turns. If I lightly tap on it it doesn't do anything.
Is it a 2 part piece maybe? I tried to grab it with pliers from the backside (inside door panel) and turn it with the alan key but seems to be one piece.. Before I get frustrated and do something I regret I will keep checking here for help. I just got done pulling the motor and I could figure that out... This little plug is winning right now
Old 10-17-2015, 06:44 AM
NumberDummy
That's an expandable fastener, the screw causes it to expand, retaining it in place. It was originally hand pressed into the hole of the door. Getting it oughtta there can be a real b!tch.
Try vise grips, lock on the outside of it...then pull.
Old 10-17-2015, 07:17 AM
Riskit's Avatar
Riskit
Riskit is offline
Ok, now that I understand how it worked and what I gotta do to get it out I'll just go slow.
Thanks Number, big help
Quick Reply: Side View Mirror(s) ?
