automatic hubs...
Old May 18, 2009 | 04:49 PM
99SevenPoint3's Avatar
99SevenPoint3
Cool automatic hubs...
Ok so i finally had a chance to try the 4wheel drive on my truck and trust me it wasnt a good experience it seems like my 4wheel drive is not engaing or locking like i like to call it ... ive heard that these automatic hubs have a tendency to go bad so im jus gonna swap um out to the manual hubs from warn but anyone know the actuall part number for them ?
Old May 18, 2009 | 05:14 PM
deano-was-his-name-o's Avatar
I have had problems with my automatic ones too. I went to the manual and have never had a problem. I will see if I can look up the part number
Old May 18, 2009 | 05:18 PM
99SevenPoint3
Thanxs for taken the time to do that ...
Old May 18, 2009 | 05:23 PM
I have a napa number hope it helps
7453112
Old May 18, 2009 | 05:24 PM
That is for the kit and hubs. Should be all that you need
Old May 18, 2009 | 05:25 PM
PLC7.3's Avatar
PLC7.3
Just remember: you must stop to engage them...... if you back up with them disengaged they will unlock...... keep them engaged and they will stay there forwards or backwards.
Old May 18, 2009 | 05:46 PM
99SevenPoint3
i was trying to look um up online and i couldnt seem to find them i know napa sells the warn hubs so i jus wanted to compare foot notes... so it states u need the kit to go from automatic to manual? is that correct
Old May 18, 2009 | 05:48 PM
Yep you need a kit too
Old May 18, 2009 | 05:52 PM
try number 11690 warn number
Old May 18, 2009 | 05:53 PM
That looks like the same kit as Napa. And there should be everything you need to do the job
Old May 19, 2009 | 07:58 AM
99SevenPoint3
Thanks again Deano...
Old May 19, 2009 | 09:19 PM
99SevenPoint3
got the warn hubs from napa ... and got them installed in no time ... it took me longer to find the star tool size then it did to change n replace those dreaded auto hubs.... and the first thing i did was test um out in some loose sand n let me tell u i could tell the 4wheel drive was locked into place...thanxs again guys
