Upgrade To 2005 Headlights
Old May 18, 2009 | 08:43 PM
robjs111's Avatar
robjs111
so u recommend the 9007 silverstars with the upgraded harness?? did u like the headlight lenses from ebay?
Old May 18, 2009 | 09:44 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yes. I started with stock lights and lens, upgraded to 9007 silverstars, helped, then the wiring harness upgrade, more help. Then I went with the clear 02 style, still even more light. Now, the 05's, more light again, change over the the silverstars, not as much change as I had hope, but still some. I'm not a fan of the blue lights, so I guess I'm done.
Old May 19, 2009 | 09:27 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by shark1979
03 was the year with clear head lights. right? will they fit in a 01 with no cutting.
02-04 fit without cutting, they bolt right in but only if you get the adjuster screw assemblies with the lights! The 99-01 lights use different adjusters that will not work on the newer lights. There is no place to buy new adjuster screws (not even Ford unless you want to buy the headlight with them) and they are scarce in the junkyards.
