2001 Expedition Squeaking noise
Old May 18, 2009 | 01:48 AM
hockster2136's Avatar
hockster2136
Question 2001 Expedition Squeaking noise
I have an 2001 Expedition Triton V8 with about 108,000 mi. There is a sueaking noise coming from the right side of the truck only when in motion. At first thought it was a belt, but that looks OK, nothing loose. Sound only happens when driving, nothing when I am in the driveway. SOund is not constant, sometimes I can drive 1/2 the day and not hear it. Other times it happens all day. Sound does not go away when I hit the brakes. I recently had the front brakes done anyway. LAst summer a shop told me it was the front bearings, which I replaced but sound did not stop. When the sound is there and I am slowing down the sound decreases in volume and then stops.
Any ideas??
Old May 18, 2009 | 07:59 AM
c_hohensee's Avatar
c_hohensee
Have you tried bouncing that corner of the truck to see if you could get it to squeak? If so the first place I would look is at bushings and the lower ball joint on that side of the truck.
Old May 18, 2009 | 02:54 PM
alloro's Avatar
alloro
Replace the driveshaft u-joints.
Old May 18, 2009 | 07:34 PM
ExpySport's Avatar
ExpySport
I'd also say check the sway bar bushings. I developed an intermittent squeaking sound while driving and more noticable when going over bumps. Ended up being the sway bar bushings needing replaced.
Old May 21, 2009 | 08:33 AM
jimvw57's Avatar
jimvw57
My 99 squeaked for about a year, then the lower ball joint broke. After replacing all 4 ball joints, the squeak is gone. THe new ones have grease fittings on them.
craigh5100
Dec 27, 2019 12:21 PM
n.shift
Aug 12, 2017 09:35 PM
daveplot
Sep 5, 2016 11:10 AM
fordf2501
Jun 1, 2016 08:22 PM
03expymg
Oct 2, 2012 12:13 PM
