7.5L or 5.8
Old May 18, 2009 | 01:14 AM
e250guy's Avatar
e250guy
7.5L or 5.8
to replace my '94 4.9? I know this isn't the engine swap section but I thought I might have a better chance of getting an answer over here. Anyway, what all would I need other than the obvious motor and mechanical parts? I've never done a computer controlled engine swap so I'm not too sure what all electronics I would need or would be necessary to replace. I assume the main things would be a computer and harness.
Thanks
Old May 18, 2009 | 10:05 AM
Conanski's Avatar
Conanski
Yes you'll need all those things, and a transmission too if you opt for the 460. Neither of these swaps is going to be simple since you're starting with a 6 cylinder, but at least the 5.8 will bolt up to the existing tranny. You will also need the frame perches and mounts for the V8 as well as the rad.
Old May 18, 2009 | 11:32 AM
2000Ford2000's Avatar
2000Ford2000
Go for around an 88 or somewhat newer 460 from an RV. Usually it's low mileage and the 88 was fuel injected but had limited computer control with the old OBDI system.
Old May 18, 2009 | 11:40 AM
e250guy's Avatar
e250guy
I could swear my 93 460 had an E4OD. Maybe not.
I hear ya on starting from scratch. Probably gonna cost me a small fortune by the time I get all the necessary V8 parts together. Might be easier to find a van with a 5.8 and go from there.
If I went that route, I don't know even where to begin looking for one. A regular bone yard?
nstueve
May 21, 2010 10:28 AM
bdwilli75
Mar 2, 2010 07:14 AM
67jc
Oct 9, 2003 03:32 PM
JasonBoBasin
1997 - 2003 F150
Mar 5, 2002 08:42 PM
vanaddict
Jun 30, 2001 05:20 PM
