Allignment question
Old May 17, 2009 | 09:28 PM
hollerg's Avatar
hollerg
Allignment question
Where can I find the design camber toe-in and caster settings (w/ tolerances) for my Mountaineer, 98, 5L V8 2wd?
I read an interesting claim on another web site. Is it true that "radials tires don't like more than 1/32nds of an inch toe-in (0.06 degrees) PER SIDE" and "typically published alignment tolerances are twice that"?
Thanks
Old May 21, 2009 | 09:02 PM
steve(ill)'s Avatar
steve(ill)
the "design" values cover a wide range. i set the toe in at 3/16 inch total. i use a level to see that the tire vertical is tipped 1/4 to 3/8 inch inward toward the motor at the top edge. closer you get to these values, the less tire wear you have. after 20k miles you can see any wear pattern and adjust the toe in-out slightly if needed, but 3/16 normally is best.
jhobbs26
May 30, 2013 03:41 AM
Crocodile000
Mar 7, 2013 07:29 AM
jrfiero
Oct 15, 2010 03:48 PM
BolderKeith
Apr 20, 2006 06:02 PM
85351ho
Jun 29, 2001 12:26 AM
