p0305 and p0300.
first is misfire in cyl 5
second is misfire in all cyl.
engine is not running rough.
2 tanks of fuel avg is 16+. i thought it was fuel but apparently not. had fresh shell 87 at the beginning of the trip then filled with bp in another state. thought the code would clear.
how many mile are on it could be alot of thing o2 sensors there should be changed at 100.000 dirty fuel filter pluged up egr stuff bad coil packs vac leaks just food for thought
