Anther CL find - 01 PSD engine
Old May 16, 2009 | 09:23 AM
Ponyboychris's Avatar
Ponyboychris
Click Me
Just an FYI.
Old May 16, 2009 | 09:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I wonder what turbo that is? The spider or no spider don't look right.
EDIT: Could it be an engine out of a van?
Old May 16, 2009 | 09:43 AM
bfife's Avatar
bfife
still plays with trucks
that would be my guess Rick. that intake is a non intercooler intake. Out of the turbo and straight to the heads. but it appears to have an EBPV and I thought vans didn't have those. as Timmy Wilson sayys " I could be wrong". Barney
Old May 16, 2009 | 09:44 AM
Kwikkordead's Avatar
Kwikkordead
That is an OBS engine, mechanical fuel pump under the turbo and no intercooler.
Old May 16, 2009 | 09:45 AM
Kwikkordead
There is no way that engine is out of a 2001!!!!
Old May 16, 2009 | 10:02 AM
bfife's Avatar
bfife
Dan, how did you see a fuel pump in that picture?? 1st generation powerstroke was my first thought also but I couldn't see enough detail to verify. Barney
Old May 16, 2009 | 07:59 PM
Kwikkordead
I didn't, I just know that they are there on the OBS.
Are there some PSD's that have that sort of intake, but with an electric pump on the frame?
Old May 16, 2009 | 08:56 PM
miller_feed
I think you are right Dan. Look at the exhaust housing flange, it's square, not round like ours.
Old May 16, 2009 | 09:03 PM
Smokin''s Avatar
Smokin'
Smokin
My first impression was... that don't look right.
Old May 16, 2009 | 09:17 PM
shark1979's Avatar
shark1979
you guys are on top of your game. thats why i come here for info about a 99-03 7.3, cause that looks like a diesel to me. the spider does not look the same but other than that you got me.
Old May 16, 2009 | 10:10 PM
Izzy351's Avatar
Izzy351
OBS type or not, that's pretty cheap... Too bad it's mis-represented as an '01. But for $800, you could take the accessories off your later engine when you're done building that one into a monster PSD.....
EDIT: I thought about replying to the ad -- has anyone done that?? Maybe whoever listed it was duped into thinking it was an '01.
Old May 16, 2009 | 10:24 PM
big poppa's Avatar
big poppa
First thing that caught my eye was the waterpump, doesn't look like ours but nice find otherwise Chris if someones interested..
Old May 16, 2009 | 10:27 PM
mueckster's Avatar
mueckster
When did they change from 2 UVCH connectors to 1? I noticed that engine has 2. Could be a van engine, but turbine housing has early model flange. OBS waterpump, unless it had been changed out. Oil pressure switch "speaks" OBS, too. Everything seems to point to an OBS engine.
Old May 16, 2009 | 10:35 PM
miller_feed
Also, the oil filler cap is on the VC without the extended tube.
Old May 16, 2009 | 10:37 PM
shark1979's Avatar
shark1979
what is UHVC? and OBS?
