Transmission temperature gage
Old May 15, 2009 | 08:58 PM
jlsdcen2's Avatar
jlsdcen2
I have an 06 F150 5.4 x 3.55 and I pull a 6000 lb travel trailer. Most of my excursions have been short (less than 100 miles one way), but this summer I hope to pull some distant trips. I read a lot of forum talk about monitoring the transmission temperature. My truck is box stock and I am looking for advice as to where I can purchase a trans temp gage, what brand or type does everyone recommend, and where does it install onto the transmission? Also, what temperature should it run max? Thanks in advance for the help. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old May 16, 2009 | 07:59 AM
shorebird's Avatar
shorebird
I have a Autometer trans temp gauge on my '01 van. Gauge is on an "A" pillar mount.
The sensor is mounted in the inspection port of the 4R100;
I recently purchased a MSD Superchips Lazer Transmission Temperature Gauge from a E-bay dealer for a quarter of the retail price. It will be going into the '08 F-150. The sensor will be mounted into a port that will be welded into the pan.
It is going into this mount;
As for the temp range here is a thread on it; https://www.ford-trucks.com/forums/8...uid-temps.html
Old May 16, 2009 | 09:26 AM
jsoko's Avatar
jsoko
temp with no load, 70-90 F outside temp--146F trans temp
when I pull 6800# it stays below 168F
OD off at 60MPH
5.4 , 3.73LS tow Pkg. with trans cooler
Old May 16, 2009 | 02:47 PM
HankMurphy's Avatar
HankMurphy
Wonderful pictures. Can you tell me where you got that gauge mount? (I'm getting a used pillar mount, but I'd like to know about those as well.)
I'm guessing you have an Autometer Z-series electrical gauge?
Also, do you know if there is an equivalent inspection port on the 4R75E transmission?
I'm going to open a separate thread on the 4R75E mount, but thanks in advance for any information you can share.
Best regards,
Old May 16, 2009 | 06:11 PM
shorebird's Avatar
shorebird
I think that you are asking about the dash mount. It is from Lotec at; www.gaugepods.com // Lotek Inc.
Yes they are Z series. Trans temp and vacuume.
Don't know about the 4R75E port sorry.
Old May 16, 2009 | 08:11 PM
jlsdcen2's Avatar
jlsdcen2
Gentlemen, thanks for all of the advice. Does anyone have any idea what model my transmission is? 06 F150 5.4 with Electronic 4 speed Automatic Overdrive. From the under side it says "Metric" on the pan.
Thanks Again
Old May 17, 2009 | 12:06 AM
HankMurphy's Avatar
HankMurphy
Thanks Again
While I won't discourage anyone from spending quality time under their F150...just had some myself...it might be easier to use the Door Sticker Decoder article here on FTE:
https://www.ford-trucks.com/article/...r_Decoder.html
It is a little out of date, though, and doesn't include the 4R75E or 5R110, for example. But if you have transmission code U, that's a start.
There are also some others on the internet.
Best regards,
Old May 17, 2009 | 01:34 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
4.2 engine - 4R70E (code "A")
4.6 engine - 4R70E (code "A")
5.4 engine - 4R75E (code "Q")
data from Page 324 of the 2006 Owners manual (Door Sticker Decoder).
Old May 17, 2009 | 06:31 AM
Sako 75's Avatar
Sako 75
Just a thought. Why not drop the $375.00 for and edge evolution. Use the level 2 towing program and setup your monitor for - trans. temp, turbine shaft input speed, output shaft speed and engine coolant temp. Do custom programming for shift firmness. All inclusive and best of all - plug and play.
Old Mar 15, 2012 | 08:10 AM
briangelc's Avatar
briangelc
how to do it?
reviving an old topic here. I tow 5000lbs in the virginia mountains at speeds 65mph+. Extra tranny cooler installed because I dont know if this truck's OEM radiator tranny cooler is up to the job. But I wonder what my temps are????
I want to hook up an ATF temp gauge too. Shorebird, if you can remember, what size sensor and thread pitch fits in that inspection port bung? also, when you opened the cover bolt from that bung, did fluid flow out? how does the gauge work??
Old Mar 15, 2012 | 10:59 AM
jlsdcen2's Avatar
jlsdcen2
transmission temperature gauge
I ended up going with a "plug and play" unit called a ScanGauge II and am very happy with it. I was not crazy about tapping into the transmission ports and / or lines which many gauges require, for fear of causing a leak or other issues. With the ScanGauge II you do not even have to crawl under the vehicle. The ScanGauge II plugs into the OBD "computer port" under your dash and utilizes all of the existing sensors that are already in your vehicle. Go online and google ScanGauge II and read up on it. I believe I paid around $160 for it and would recommend it to anyone.
Old Mar 15, 2012 | 02:52 PM
briangelc's Avatar
briangelc
thanks jlsdcen2, i have actually been trying to avoid buying a SCii, but it looks like it may be the easiest way out. A $25 guage would be nice, but only if i dont have to spend half a saturday figuring it out and running to the parts store for adapters and such. I alreaady have 2 other OBDII readers, so I dont really want a third
Old Mar 15, 2012 | 09:05 PM
18wheelin's Avatar
18wheelin
I love my Scangauge. Will never do without it again.
Old Mar 15, 2012 | 09:19 PM
briangelc's Avatar
briangelc
yes they are friggin cool. and the resale on on is suprisingly high
Old Mar 15, 2012 | 09:30 PM
shorebird's Avatar
shorebird
The sensor came with the Autometer gauge.
http://www.google.com/products/catal...d=0CIcBEPMCMAI
No adapter was needed.
As for the port it is above the fluid when the engine is off so no leakage occurs.
