Sponsored by: Real Truck
brake controller question
Old May 14, 2009 | 03:47 PM
ultramag's Avatar
ultramag
With the brake control set on 10, when somebody hits the break pedal what voltage should I read at the trailer connector?
Old May 14, 2009 | 03:50 PM
dchamberlain's Avatar
dchamberlain
There is no simple answer to that. If the brake controller is set to 10, that is the maximum voltage it will put out, generally.
Taking for example a Prodigy inertial controller. If you set it to 10 and hit the brakes, the output will be somewhere between 0 and 10, depending on the deceleration sensed by the brake controller.
If you set it to 10, and pull the manual handle all the way over, you should read 10 volts at the plug.
Old May 14, 2009 | 05:31 PM
bpounds's Avatar
bpounds
OP has an '07 F350, so I'm thinking he has the Ford TBC. If so, if you are sitting still and just press the brake, you won't get much voltage out of the controller. On the other hand, if you squeeze the manual override levers, you should get a good hard brake out of it. Can't tell you what the voltage would be. Never needed to measure it.
Old May 14, 2009 | 07:25 PM
ultramag's Avatar
ultramag
Thanks for the replies, feel like a real idiot now never thought about inertia switch, no need in having power to the trailer brakes if the tow vehicle is parked.
Old May 15, 2009 | 07:55 PM
rob17's Avatar
rob17
I don't know about that. If I were stopped on a slipper hill (ice, gravel, grass, whatever) I would want all wheels holding no just the truck's wheels.
Rob
Old May 15, 2009 | 07:59 PM
bpounds's Avatar
bpounds
That's one of those oh sheet moments when using the oh sheet lever is suggested. Sheet ice!!!
Old May 15, 2009 | 09:30 PM
dchamberlain
I don't know about the tow command, but the Prodigy controllers apply 1-2 volts when standing still to help maintain the parked condition.
scraprat
All Things Towing
Jan 4, 2015 09:16 AM
billybobzia
2009 - 2014 F150
Jun 10, 2014 04:53 PM
Vinford
All Things Towing
Sep 27, 2010 04:21 PM
horsepuller
All Things Towing
Nov 7, 2006 02:59 AM
loudfords
All Things Towing
43
Oct 19, 2004 08:33 AM
