Keyless Entry Problem
Old May 13, 2009 | 09:06 PM
danlee's Avatar
danlee
I replaced the original battery on my 2002 Mecury Mountaineer. Since then my Keyless Entry Keypad doesn't work. I tried to reprogram using the Factory Default Code, but that doesn't work either. The Keypad will lock the doors, but that doesn't require a code. I believe the Factory Code is the same one as I used when the vehicle was new.
Also I can only program one Remote Door Lock. I can program the first one, but if I try to program another, neither will work. I have to disconnect the battery and start all over with programming.
The Keypad doesn't illuminate when I try to enter the Factory Default Code.
Old May 14, 2009 | 06:20 PM
Franklin2's Avatar
Franklin2
This may be a dealer thing with their scanner. I don't have a clue myself what would be the problem.
Old May 14, 2009 | 06:30 PM
danlee's Avatar
danlee
I located the Security Control box, and verified that the Default Code is the same as the one that I have been trying. Somehow the code must have gotten jumbled, or the box itself. The Theft Alarm seems to work OK, as does other things. It's only the Keypad and the second Remote that won't work.
Old May 15, 2009 | 07:28 PM
danlee's Avatar
danlee
Is there any way to reset the Security Module?
Can I disconnect the battery (-) terminal and tap the brake to discharge caps in the Module? I know that works with the EEC-IV Engine Modules.
Old May 27, 2009 | 08:41 PM
danlee's Avatar
danlee
The dealer wants $149.00 to run a diagnostic program. There is no gaurantee that it can be fixed with a reprogram. I can buy a used BCU from a wrecked vehicle similar to mine for $50.00.
My question is:
Can I swap the Body Computer from another vehicle without confusing the other Computers.
I ran an OBDII scan and did a reset on the one stored EGR differential pressure code. I have replaced that unit once already.
Old May 27, 2009 | 08:55 PM
Franklin2's Avatar
Franklin2
I know you can't swap in a different instrument cluster. I am not sure about the body module.
Old May 28, 2009 | 10:05 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have you thought about you having a bad keypad? To lock only requires #9 and 10 to be good. Even if you have only 1 pair of numbers bad, that's enough to screw you over. I think the pads are pretty cheap.
Old May 28, 2009 | 06:23 PM
danlee's Avatar
danlee
I pressed each pad, one at a time and observed that the light under the mirror goes on for each pad. I let the light go out before I tried the next one.
I thought that the keypad itself used to light up, but I don't think that it does now.
Does the Keypad light up?
Old May 28, 2009 | 08:54 PM
danlee's Avatar
danlee
I waited until daylight was gone and checked the Keypad. It does light when a key is pushed. It can't be seen in full daylight, so I wasn't sure that it light up.
It could still be the Keypad, the light might be set in a different circuit than the Pad Encoder.
Will104
Oct 16, 2017 05:40 PM
MackGuy
Nov 28, 2016 09:27 AM
ken1509368
Feb 1, 2016 01:11 AM
simplywebb
2004 - 2008 F150
Mar 18, 2014 06:02 PM
linedog
Dec 14, 2008 12:12 PM
