T-case fluid change
Old May 13, 2009 | 08:02 PM
7.3 Rocket's Avatar
7.3 Rocket
T-case fluid change
I want to change the fluid in my transfer case, but I won't have any real long stretches of straight road I could run in 4x4 to get the fluid warmed up.
I have a manual t-case and I'm wondering if I could put the t-case in 4x4 high, but leave the hubs disengaged.
Would it work to heat the fluid up and would it damage anything if I did that?
Old May 13, 2009 | 08:21 PM
triskit16's Avatar
triskit16
I changed mine relatively cool. Parked it on a slight incline and it all dripped out in a timely manner.
Old May 13, 2009 | 09:15 PM
DieselCamper01's Avatar
DieselCamper01
I did mine cold on an incline also. Worked well Pete.
Old May 13, 2009 | 09:29 PM
big poppa's Avatar
big poppa
I took mine out for about 3 miles or so with the hubs unlocked but in 4x4 and then I drained it and filled it with 2 quarts of syn. mercon-V, old fluid was dark at 115.000, I will be changing on a regular basis now that I seen that. I do believe if I remember, its a 10 mm metric allen wrench, I had to borrow because I didn't have one in that size.
Old May 13, 2009 | 11:16 PM
rebelchevy02's Avatar
rebelchevy02
FWIW, it wont make much difference, running in 2wd, vs 4wd, as far as heating the oil. In both situations, the case/input gets most of its heat from the transmission, and the fluid just circulates. Enableing 4wd, only allows the drive chain, to be engaged. Nothing really causes heat, in a transfercase. And it is actually filled with ATF, which flows out pretty well. If your that concerned about getting ALL the old fluid out, start in the morning, after letting it sit over night. That way any of the pumped, or slung oil is at the bottom of the case, put a pan under it, and let it drain. And if your really going crazy, let it sit an hour.
When I did mine, the truck was up to temp (just drove it) and I drained it, and then refilled. IMO its really no big deal, to make sure you get every ounce of old fluid out. Our transfercases have no clutches, or wear items in them. Only occaisional services they need, are oil seals, and rarely, you can stretch your chain enough to be an issue. But Ive only even done that on smaller cases, havent heard of it in a NV 271 or 273, unless it was from a dedicated sled puller.
Eddie C
Oct 14, 2014 06:35 PM
Jim-bo77
Feb 5, 2014 05:33 AM
66f1004x4
Offroad & 4x4
Feb 3, 2010 05:30 PM
Broncobirdy
Jan 29, 2007 12:02 PM
96f150
Mar 19, 2002 06:47 PM
