98 ranger Trans issue
Old May 13, 2009 | 08:12 AM
bad12jr's Avatar
bad12jr
Have 1998 ranger 4cyl with automatic. Whenever it gets above 60 the OD light flashes. It goes into limp mode. Had a similar problem with my E4OD but not as familiar with this trans.
Thanks guys
Old May 13, 2009 | 09:11 AM
tomw's Avatar
tomw
Go a little further down the list of topics on this board and you will find a section under:
"Misc" for "clutch, transmission, differential, axle and transfer case"
You should get a lot more traffic on your question.
I don't have a good answer for your question, but just general transmission info. Check the fluid for odor, color and full condition. If it is dark and burned smelling, you likely have internal problems causing overheating, or the fluid has a lot of miles without changing. If the level is low, top it off, which you probably have already done.
tom
Bear 45/70
Feb 19, 2009 01:37 PM
BlackLariat4x4
Apr 24, 2008 06:33 PM
Chip127
Feb 7, 2005 06:15 AM
Sand Bronco
1978 - 1996 Big Bronco
Feb 3, 2004 10:57 AM
