stupid air!!!
Old May 13, 2009 | 01:33 AM
rupejosh's Avatar
rupejosh
stupid air!!!
well i went and changed my oil and my inline fuel filter i put in to bypass the leaky filter head that i have yet to finish fixing.lol and now the dang truck dont start.checked voltage to ip and its all good used the gas soaked rag.i tried turning it over atleast a dozen times now what?
Old May 13, 2009 | 02:07 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Did you bleed the air out??
-Enjoy
fh : )_~
Old May 13, 2009 | 03:36 AM
rupejosh's Avatar
rupejosh
ya i have an electric fuel pump on a toggle switch.probably gonna have to crack injectors huh?i figured letting the electric pump buid pressure for a while and cranking it over a few times would get rid of the air
Old May 13, 2009 | 04:28 AM
Lazy K's Avatar
Lazy K
First thing is to loosen the fuel feed pipe at the injector pump a couple of turns and run the electric fuel pump untill fuel comes out with no air. Tighten pipe nut. May take a bit of cranking but it should then start.
Old May 13, 2009 | 10:37 AM
Festus Hagen
Methanoholic
I agree with Lazy K!
IP Pump, Injectors and lines will bleed them selves out in just a few cranks.
-Enjoy
fh : )_~
Old May 13, 2009 | 12:09 PM
David85's Avatar
David85
+3.
Bleeding the injector lines is not really required. Mine will simply push the air through and fire off after about 5-10 seconds of total cranking with an empty injector pump.
Old May 13, 2009 | 08:23 PM
rupejosh's Avatar
rupejosh
cracked 3 injectors this morning and fired right off.
