Old Aug 6, 2002 | 04:42 PM
jberylecrider's Avatar
jberylecrider
Any input would be great guys...
I have been through two sets of "genuine gears" now.
This time I want to do it right! Both previous times the pinion teeth were chiped off, not all, just some of them but the ring gear was fine. The chipped off parts were the inner most half of the tooth closest to the carrier. The back side of the teeth closest to the bearing was intact.
I thought it was from the pinion binding with the ring gear because there was not enough carrier preload, but turns out there was plenty of preload.
The backlash was setup good, the only thing was that we couldn't get the drive & coast patterns perfect. With the ring gear laid down teeth up, then the drive surface pattern was to the outside edge, and the coast pattern was to the inside edge. Both were off center by about .75 inch.
Would this be enough to chip pinion teeth like that?
Help me!
Thanks
Old Aug 8, 2002 | 06:32 AM
rabidranger's Avatar
rabidranger
8.8
Oh yeah. The bearing preload and the backlash are important enough, but the wear pattern is probably the most important. Even if you have to take the axle assem apart 100 times and keep adding/removing shims, the wear pattern determines the life of the gears.
You should setup the gears adjust the bearing preload, then check the backlash, then paint the gears and check the wear pattern. If any of the above fall out of spec, tear it apart and re-shim.
Although R&P are supposedly the hardest thing to do to your rig, they just require patience. Good Luck.
Old Aug 8, 2002 | 11:11 AM
jberylecrider
Ya, LOTS of patience!
Thanks
Old Aug 8, 2002 | 01:47 PM
MustangGT221's Avatar
MustangGT221
I bought a good video on ebay for rebuilding the 8.8, it's from Ken, the guy I told you about with the 30 years of experience before. I recommend Ford Racing gears from summit racing, about 190 bucks. Best set you can get.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 8, 2002 | 01:55 PM
jberylecrider
I'm pretty sure that even the Ford Racing guys use Precision or Richmond gears. I have been told that these are the best. So thats what I bought. I didn't even think about Ford Racing gears, wish I had so I could get peoples opinion on those vs precision vs richmond.
Thanks though!
Old Aug 8, 2002 | 02:58 PM
MustangGT221
Lots of guys on here recommend ford gears because they are a stock replacement quality. No idea about the relationship with other companies but, thats what I was told to buy, and I seeked a few opinions from here.
Then theres:
99' Mustang GT 4.6L
Old Aug 8, 2002 | 09:56 PM
Ryan50hrl's Avatar
Ryan50hrl
8.8
i love my ford racing gears...i've had them in my truck and car and never had a problem..they would be my recomendation.
ryan
Old Aug 8, 2002 | 10:05 PM
klowak's Avatar
klowak
Post 8.8
