Quick Radio Wire Question
Old May 12, 2009 | 08:25 PM
girlwithatruck's Avatar
girlwithatruck
Question Quick Radio Wire Question
Hey All,
My question for today is about my radio: I grabbed an OEM radio at the salvage yard this weekend (i was giddy with the thrill of disassembling trucks!) just hoping that it might actually work when connected. (I think it came from an 84 but i could be wrong.)
Now based on what i've found on the forums about the wiring, I seem to have fewer wires coming from the back of it than other people do. As you can see from the pic i have:
yellow with brown
blue with red
black with white
black with green
The wiring from my truck dash looks like solid yellow, then 4 strands of speaker wire (even though i only have 2 speakers) and of course the antenna plug.
Am I missing any wires? Will this work? Is there anything I need to know about connecting things up?
As always, thanks so much for any help!
Old May 12, 2009 | 08:38 PM
bashby's Avatar
bashby
I'll guess that the yellow with what looks like a fuse goes to ign+, white/red goes to dash light circuit and the other 2 go to a speaker. Ground is probably through the radio chassis
Old May 12, 2009 | 08:57 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I agree to a point, then unsure.
Yellow = Ing/acc positive.
Blue/Red = Dash lights.
Ground is through the stud sticking out the back.
The speakers are where I am unsure.
Left and Right channel (second leg is ground)
or
Mono (both to one speaker)
Someone will be along shortly that knows for sure!
-Enjoy
fh : )_~
Old May 12, 2009 | 09:00 PM
FordNFishinLover's Avatar
FordNFishinLover
Thats the same as my old radio that i replaced with a new MP3/cd player.
The wires should go to illumination, speakers, and power...i believe
i think on the top of my radio it had a sticker telling what each wire was? Tomarrow i will take a look for you and tell you what i find.
Old May 12, 2009 | 09:35 PM
ctubutis's Avatar
ctubutis
Look at the tuner, it's AM only.
LightBlue/Red stripe == dimmable dash backlight
Yellow/Black hash == switched power supply, I believe 15A but not sure.
The black with colored hash marks are speaker wires.
Ground is the big bolt in back.
Hopefully, 81-f150-explorer will be by sometime to confirm, he's got all wiring diagrams.
Old May 12, 2009 | 09:42 PM
88-150's Avatar
88-150
hey that looks like the one i got only mine has a casette below the needle. I agree, looks like power, illumination and speaker left/right with chassis as ground. I got done tearing one of those apart a few weeks ago. Found it under the trailor and it smoked with i hooked it up. Oh well.
Old May 12, 2009 | 09:55 PM
ctubutis's Avatar
ctubutis
I feel like Stosh.... Did you not read what I wrote? If you look at the front of the tuner,
you can plainly see there is no FM dial, which means it's an AM-only radio with one
speaker.
Old May 12, 2009 | 09:57 PM
88-150's Avatar
88-150
well seeing how i've never seen an AM only radio, i think that was bit uncalled for.
It wasn't till I got the casette deck that I have in there now that I found there's no controls for bass.
EDIT: You might need to splice in the wires since it doesn't have the 4-prong socket on it. Not hard to do, just need tape cutters and wire srippers.
Old May 12, 2009 | 10:12 PM
ctubutis's Avatar
ctubutis
AM radios don't have separate bass & treble controls, they have one **** used for tone
adjustment.
Old May 12, 2009 | 10:30 PM
88-150's Avatar
88-150
even though what i've got has both fm and am selection? I usualy don't stick to origional parts when I buy a truck, but I figured I'd be different. The difference between the Ford radio's is all new to me.
Old May 12, 2009 | 10:45 PM
girlwithatruck
hahah...see this has gotten more complicated than i thought it would be already...i know it's an AM radio so i'm cool with that but i had no idea that would impact the number of speakers i got sound through...see how spoiled i am? AM goes through all the speakers in my every day driver so it never crossed my mind that i might have a speaker issue...will it still work with 2 door speakers?
Old May 13, 2009 | 08:06 AM
bashby's Avatar
bashby
It should run 2 speakers fine if you run one wire from the radio to both speaker + and the other to both -
Old May 13, 2009 | 12:46 PM
girlwithatruck
this may be a stupid question but do i have to solder the wires together or can i just twist and tape them?
Old May 13, 2009 | 12:58 PM
Mental Case's Avatar
Mental Case
You can tape them just to see what works and whatnot, but if you solder them then you won't have to worry about the wires coming apart.
Old May 13, 2009 | 01:30 PM
86bigred's Avatar
86bigred
don't twist and tape them.thats hacker wiring.you don't have to solder the wires ether.just go out and buy a crimping toll and various connectors.i only solder and heat shrink wire, if it will be exposed to the elements.
