Quick ATF question!!
Old May 12, 2009 | 08:15 PM
YZGUYONE25's Avatar
YZGUYONE25
Okay... I need to service my tranny as I am unsure of the miles since last service. I got the filter and about 8 quarts of Mercon V. Then I found out about draining the TC and figured it needs more! So, my buddy gave me a case of Dexron III/Mercon.
My question... can I mix the two, Mercon V and Dexrom III/Mercon??? I am dumb when it comes to these fluids. Also would rather spending another $50 for 10 more quarts of ATF!
Thanks!
Turtle
Old May 12, 2009 | 08:24 PM
don77's Avatar
don77
i wouldnt mix them myself but it hold about 16 quarts
Old May 12, 2009 | 11:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
you can mix them. they dont even make dexron III anymore. you buy merc V and it is suitable fore all fluids now.
Old May 12, 2009 | 11:49 PM
YZGUYONE25's Avatar
YZGUYONE25
Good answer Joe! I was hoping I would be able to mix them. I guess tomorrow morning I will drain the fluid and attempt the infamous mod for my shifts!
Thanks.
Old May 13, 2009 | 01:52 AM
joe_13894's Avatar
joe_13894
Some tips on changing the fluid.
You can disconnect the fluid line from the rear of the transmission and lead it to a bucket with a 5/16 plastic tube. Then run the engine until the fluid runs out. That lets you drop the pan without dealing with 12 quarts in the pan.
After you dump the pan, drain the TC by pulling the plug. Disconnect the front cooler line and then blow compressed air into the front cooler fitting on the transmission. This will blow out the pump and the passages to the TC. Then blow out the cooler, and finally blow out the lube passages by blowing into the rear cooler return. Doing this will get a LOT more fluid out than just draining the pan and TC.
