What axle do I have
Old Aug 9, 2002 | 05:40 PM
87ford4x4inline6's Avatar
87ford4x4inline6
What axle do I have
The code on my sticker is 18 which I think is a open 3.08 gearrearend. How do I find out what front axle I have? and What transfer case I have? The truck is a 87 F150 4x4 4.9 efi.
Sticker show built in 3/87. Thanks for the replies in advance.
mike
Old Aug 9, 2002 | 05:48 PM
jberylecrider's Avatar
jberylecrider
What axle do I have
[updated:LAST EDITED ON 09-Aug-02 AT 06:50 PM (EST)]Front end is a Dana 44 TTB, probably geared at 3.55:1 or 3.73:1
Rear end is a Ford 9" or 8.8" Geared the same as the frontend.
Is your truck a manual or auto transmission? This info will help find out what xfer case you have.
Old Aug 9, 2002 | 07:45 PM
MustangGT221's Avatar
MustangGT221
What axle do I have
The rear is an 8.8, the front is a d44 TTB, but it has 3.08 gears. Front and rear gears must be within 1% of each other.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 9, 2002 | 07:46 PM
MustangGT221
What axle do I have
And the trasfer case should be a borg warner 13-56. Crawl under there, it's stamped right on it.
Then theres:
99' Mustang GT 4.6L
Old Aug 9, 2002 | 08:06 PM
kspilkinton's Avatar
kspilkinton
What axle do I have
Just throwing my two cents in here, but I've got a question. When I was researching possibly dropping the gear ratio in my truck, I found the 3.08 in a standard rotaion only for the D-44. Aren't the D-44 front ends a reverse rotation? If they are, the smallest ratio that I can find is a 3.54.
Not saying you're lying Mike. Maybe my info is wrong.
-Kerry
Old Aug 10, 2002 | 12:06 AM
jberylecrider
What axle do I have
Dana 44 TTB is high pinion (reverse cut rotation)
Dana 44 Solid is low pinion (standard rotation)
My friend runs 5.88:1 gears in his, so I know they make 'em.
Old Aug 10, 2002 | 01:07 AM
Brian460's Avatar
Brian460
What axle do I have
Actually somewhere around 76-77 the dana 44 solid axle became high-pinion.
Brian:-)
Old Aug 10, 2002 | 01:12 AM
87ford4x4inline6
What axle do I have
thanks for the input. Tranny is 4 speed.
Not sure what gears I have in the rear. The axle code on the sticker is 18 and I seen somewhere that that means its a 3.08 regular. I am doing some more research on it .
Old Aug 10, 2002 | 07:33 AM
jwtaylor's Avatar
jwtaylor
What axle do I have
78 & 87 Super Cab
Dec 15, 2012 09:56 PM
mcn420
Apr 20, 2006 05:58 PM
jeff8abug
Dec 26, 2004 02:31 PM
renoduckman
1983 - 2012 Ranger & B-Series
Oct 28, 2004 07:40 PM
notburger
Mar 27, 2002 09:00 AM
