Tire Rub
Old May 12, 2009 | 11:44 AM
CanadianSmokie's Avatar
CanadianSmokie
Tire Rub
I tried posting this in the 4X4 section but wasn't getting any responses...
I have yet to install my 35" MT's on the Excursion but was wondering what issues I could possibly have with rubbing and how to fix it?
The new rubber is mounted on new 8" rims with better backspacing than stock, so I imagine the rub on the leafs will be eliminated. The truck will also have a very mild 2" levelling lift up front with and extra 1.5" increase in the back.
I was looking at the stock wheels on it now (265/75/16) and noticed they are awefully close to the back of the front fender when the wheel is turned. Is this going to be my problem area? How are the fenders "trimmed" to avoid this?
Thanx for your help... <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Old May 12, 2009 | 04:21 PM
ReAX's Avatar
ReAX
Trimming the fenders to not rub is simple, you find out where your rubbing and remove that part of the fender. The plastic is pretty easy to trim, I like using a variable speed drimel with rotozip bits and a flex shaft. It cuts like butter.
Because you changed the backspacing, it's also changed where the tire is likely to rub. I think less back space makes the corners of the tires travel further.
Old May 12, 2009 | 06:37 PM
CanadianSmokie
Oh, ok, so it's the inner fender that gets trimmed.... to me trimming the fender requires metal removal.... whew!!
Old May 12, 2009 | 06:44 PM
ReAX's Avatar
ReAX
You only have to cut the metal if the tire is bigger than the opening and the axle is centered in it, I think the stock opening is around 42". With 35" tires, you should rub only on the inside, no metal contact.
Old May 12, 2009 | 09:03 PM
wallz's Avatar
wallz
I think some have also used a heat gun to heat up the inner plastic fender were they get rubbing and bend that area in to get the clearance.
Old May 12, 2009 | 09:08 PM
ReAX's Avatar
ReAX
It takes a lot of heat to make the plastic malleable. I hair dryer shouldn't cut it, but a professional heat gun should do. For doing lexan, I think it was 400 degrees for 10 minutes in the oven to make it moldable, it's probably the same for the plastic used near the manifolds or higher. Once you get is hot, a pair of tongs is supposed to make nice bowl shapes. Just push them in and spread them.
Old May 12, 2009 | 10:42 PM
CanadianSmokie
Excellent tips! Thanx...
Getting the lift and tires put on Thursday... will let you know how it goes. Shocks will have to wait till later....
2000gpr
2004 - 2008 F150
Jul 29, 2009 09:39 PM
Eddiestruck
May 5, 2009 04:18 AM
rat49f6
Apr 4, 2009 09:22 AM
78F150RangerXLT
Mar 22, 2009 01:56 PM
quietman
Mar 7, 2009 09:36 PM
