Downshifting Hard
Old Aug 6, 2002 | 10:33 AM
D Ray's Avatar
D Ray
Downshifting Hard
When my truck downshifts from OD - It shifts REALLY hard. It only does it from OD to Drive and upshifts fine. It even downshifts in lower gears fine, just from OD it does it. It used to do it occaisonally but now does it most of the time. I can let off the gas and manually downshift on the column and then hammer it and it doesn't do it. Changing fluid/filter didn't change anything.
Any suggestions?
Thanks,
Old Aug 7, 2002 | 02:01 PM
D Ray's Avatar
D Ray
Downshifting Hard
Anyone know what could be causing this????????????????
Old Aug 7, 2002 | 05:05 PM
skywagon's Avatar
skywagon
Downshifting Hard
Did you retorque the valve body bolts? These transmissions can have all kinds of weird problems because they work loose and suck air. rk
Old Aug 8, 2002 | 04:11 PM
D Ray's Avatar
D Ray
Downshifting Hard
The tranny has never been touched except to change the fluid and filter.
Should they be re-torqued?
Old Aug 8, 2002 | 05:06 PM
skywagon's Avatar
skywagon
Downshifting Hard
[updated:LAST EDITED ON 08-Aug-02 AT 06:07 PM (EST)] Yes and also check on bullitan # 971111, your Ford dealer should have it.
Old Aug 12, 2002 | 07:11 AM
D Ray's Avatar
D Ray
Downshifting Hard
Thanks Skywagon!
How hard is it to re-torque those valve body bolts? I don't have any experience with that. Also, what lbs. should they be torqued to?
Old Aug 12, 2002 | 02:46 PM
skywagon's Avatar
skywagon
Downshifting Hard
Not too bad, remove pan and torque to 80-90- (inch lbs)there is a diagram of the torque pattern in the Ford manual but I don't have it here at this location. Just pretty much start out on the middle and work toward the front and rear like tightening a head gasket.
Old Aug 12, 2002 | 03:15 PM
D Ray's Avatar
D Ray
Downshifting Hard
I'll try the re-torque. I could use a ATF change anyway.
I also couldn't find anything on that #971111 bulletin. What was that bulletin about?
Thanks again!
Old Aug 12, 2002 | 05:17 PM
GaRedClay's Avatar
GaRedClay
Downshifting Hard
sbeamer
Aug 11, 2016 09:31 PM
Ericinkc
1997 - 2003 F150
May 27, 2016 01:03 AM
duckhunter88
Jul 28, 2013 12:48 PM
1991Aerostar
Aerostar
Jan 11, 2006 11:26 AM
Sedric
Dec 29, 2001 11:47 PM
