Cooling system issues
Old May 11, 2009 | 08:21 PM
fseries8790's Avatar
fseries8790
I have an 87 F250 with a 5.0 4 speed. Recently put new GT40 heads on and the truck ran fine for a good month or so before i blew the clutch hose. Got it running after that and now when i go to drive it coolant starts to pour out of the overflow tank after only minutes of running. If anybody had some ideas it would be greatly appreciated!
Old May 11, 2009 | 08:26 PM
393STROKER's Avatar
393STROKER
Try changing the thermostat and back flush the system.I take a garden hose and flush both heater hose`s and alway flush some rust out.
Old May 12, 2009 | 09:51 AM
Q in Sac's Avatar
Q in Sac
Check your thermostat. That's so important. And back flush your motor and radiator. My water temp gauge was bouncing up and down before I did the above. Now it stays solid (N)ormal. Also replacing you heater hoses would help also. My 2.93 cents. lol
Old May 12, 2009 | 02:37 PM
Lazy K's Avatar
Lazy K
Fill the radiator right up to the neck and run the engine. Look for a steady stream of bubbles and smell for exhaust fumes. This should tell you if you possibly have a blown head gasket. To confirm do a compression check.
Old May 12, 2009 | 02:42 PM
Old93junk's Avatar
Old93junk
Lazy K has prob. nailed it...........Not all head gaskets are created equal, and may be a suspect after the head change.
Old May 12, 2009 | 03:57 PM
phoneman91's Avatar
phoneman91
Is the truck overheating when the coolant overflows from the coolant reservoir? Does the temperature gauge show overheating? Have you pressure tested the cooling system??
Old May 13, 2009 | 05:58 PM
fseries8790
Yes the truck overheats when it starts pouring out and the gauge also reads hot
Old May 14, 2009 | 04:11 AM
phoneman91's Avatar
phoneman91
Pressure test the cooling system and if passes the test-try a new radiator cap.
jprix
Modular V8 (4.6L, 5.4L)
Dec 18, 2012 07:43 AM
johnarahill
Mar 2, 2012 06:26 PM
powerstrokeredneck97
13
May 4, 2009 04:52 PM
bememe
16
Dec 28, 2005 08:23 AM
tunruh
May 3, 2003 08:49 AM
