DP Tuner Question?
Old May 11, 2009 | 05:21 PM
Mark Buzzard's Avatar
Mark Buzzard
DP Tuner Question?
Well I have ran through all the tunes on the DP and really can't tell much of a difference between 80E and 120R. Where do you guys feel the most difference between these two tunes, low end or upper end of the RPM range. It could be that I haven't really been able to stand on it yet because of all the idiots around here. Just curious, let me know. I do have to say the 80E alone was worth it.
Old May 11, 2009 | 05:27 PM
HKusp's Avatar
HKusp
They ARE close, but I can tell a difference, especially in the amount and color of smoke between the 2. Your HPOP may be getting a little weak. The big thing is if the HPOP can keep up with the demand of the 120.
Old May 11, 2009 | 05:28 PM
Pocket's Avatar
Pocket
It's your stock HPOP that's going to limit you, and is the reason you can't feel much of a difference beyond the 80E. Back when I was still running the stock HPOP, I could hardly tell a difference in the 80E and 120 race on the top end. Both fell flat when the HPOP dropped oil pressure.
80E is a very aggressive tune anyway, and if your HPOP can supply enough oil for anything more aggressive than that, then you won't reap the benefits until you get more oil in there.
Old May 11, 2009 | 05:31 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Mark, do you have an OBA? That will limit is as well.
Old May 11, 2009 | 06:12 PM
Mark Buzzard
What is an OBA? What is the next level of HPOP?
Old May 11, 2009 | 06:15 PM
Mark Buzzard
Never mind, I looked it up and no I don't have the over boost anihalator.
Old May 11, 2009 | 06:33 PM
Riffraff Diesel
PREMIUM SPONSOR
Sounds like I will need to me I need to make you and Mike the first ones to get mine that is being built for me
Old May 12, 2009 | 09:40 AM
superduty4x4's Avatar
superduty4x4
On my truck, the difference between 80e and any of the higher tunes is the amount of smoke poured out of the tail pipes. My poor little stock injectors and stock 15* HPOP can't feed enough fuel to the motor to make the bigger tunes run any stronger.
