heater blower schematic ??????
Old May 11, 2009 | 03:28 PM
'01_4x4's Avatar
'01_4x4
Hello, I have an '01 Ranger 4x4 4.0 and my blower motor quit working.
I checked my 40A fuse and it's good. I don't have any voltage getting to the blower.
If I pull out my 40A fuse I have voltage there but I don't know where it goes from there? the switch ?????
If someone can direct me to an online schematic or get me the blower motor section that'd be great.
I will soon buy a manual. I have them for every other vehicle but this one's been rock solid so far. In the meantime any help would be appreciated.
Old May 11, 2009 | 05:09 PM
michigan66's Avatar
michigan66
Check out the resistor block that is in the heater airbox. Its located on the passenger side of the firewall in the engine compartment. It can get corroded, either at the connector or the resitor coils may have bad connections. Its easy and inexpensive to replace.
Old May 11, 2009 | 06:30 PM
'01_4x4's Avatar
'01_4x4
Thanx Michigan66, it appears the resistor block is below the blower motor? I'll check it out. I did a little searching and evidently high speed does not use the resistor block but mine won't work on any speed. That's kind of why I need a manual or schematic.
I will indeed unplug/check the resistor block though because I should have voltage there at least at lower speeds. Thanks again.
Old May 11, 2009 | 08:13 PM
Rockledge's Avatar
Rockledge
There's another fuse to check, #2 in the interior cab fuse box (10A). The circuit should be hot with the key in the "RUN" position.
Old May 11, 2009 | 08:41 PM
'01_4x4's Avatar
'01_4x4
Thanx man, it was actually the 10A fuse inside the cab. In my owners manual I seen the 40A fuse for the blower motor in the engine compartment, but yep there is a 10A fuse,#2, in the fuse panel. It's for the Daytime Running Lights, Back-up Lights, Transmission, Passenger Air Bag Deactivation Switch, and the..........DOH!!!!! Blower Motor Relay.
My truck doesn't have daytime running lights and I have no idea what it's for on the transmission but my blower works now. Thanks all !!!!!!!!!!!
jtcdudeman
Sep 16, 2016 01:05 PM
FordLou
1997 - 2003 F150
30
Dec 6, 2014 12:14 PM
Va_capone
Nov 25, 2014 06:34 PM
railbag
1997 - 2003 F150
Nov 7, 2010 07:52 PM
wattsup
Electrical Systems/Wiring
Oct 3, 2007 05:37 PM
