Sponsored by: Real Truck
Warnign Chimes Driving me Nutso
Old May 11, 2009 | 03:08 PM
MBman's Avatar
MBman
I have a 04 F350 Crew cab 4X4 with SB. I use it as a farm truck, it has keeyless entry and auto shut off for the lights
It chimes with keys left in ignition, it chimes when you do not put your seat belt on, it locks the doors when you get going over 10MPH, using it on the farm these chimes and features drive me wacko. I looked for the chime but cant find it
Anyone have any advice - can these be disabled, of course the ford dealer said no
Old May 11, 2009 | 03:56 PM
firemanpat29's Avatar
firemanpat29
key in switch takes a peice of tape to defeat. the other two are simple programing that you have to do. If you dont have the owners manual, look in the tech folder (the first thread in this section )for how to do various year models. most are simple but you must do in the exact order listed in the time specified. I have done my truck and three others. the key in switch one will not allow you to lock the doors when getting out with the normal lock button but the remote or the last two numbers at the same time will lock it.
Old May 11, 2009 | 03:58 PM
firemanpat29
sorry the tech folder is 3rd thread now, forgot about oasis and the new member stickies.
Old May 11, 2009 | 04:01 PM
cepterjockey82's Avatar
cepterjockey82
my 05 has the ability to turn off the auto door lock by pressing the setup button in front of the steering wheel twice as far as the warning bell try a drywall screw fyi do not completely remove the buzzer as you will loose function in all of your gauges
good luck
Old May 11, 2009 | 04:05 PM
tazo's Avatar
tazo
https://www.ford-trucks.com/forums/4...oor-chime.html
For the seat belt chime check your owners manual. It has instructions to turn it off.
There is also instructions to turn off the auto lock in the manual. I don't have my manual with me or I would explain.
Old May 11, 2009 | 04:55 PM
dchamberlain's Avatar
dchamberlain
Look up your owner's manual here...
http://www.genuineservice.com/genuin...loveboxresults
Old May 11, 2009 | 05:25 PM
tazo's Avatar
tazo
One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, the BeltMinder will be disabled for that ignition
cycle only.
Deactivating/activating the BeltMinder feature
Read Steps 1 - 5 thoroughly before proceeding with the
deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the
following procedure:
Before following the procedure, make sure that:
• the parking brake is set
• the gearshift is in P (Park) (automatic transmission)
• the ignition switch is in the OFF position
• all vehicle doors are closed
• the driver’s safety belt is unbuckled
• the parklamps/headlamps are in OFF position
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
2005 F250/350/450/550 (f23)
Owners Guide (post-2002-fmt)
USA_English (fus)
Seating and Safety Restraints
105
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 60 seconds after the safety belt
3. At a moderate speed, buckle then unbuckle the safety belt 9 times,
ending with the safety belt in the unbuckled state.
• After Step 3 is complete, the safety belt warning light will be turned
on for 3 seconds.
• If Step 4 does not occur within 10 seconds at the end of Step 3,
Beltminder will automatically exit programming mode without
changing its enable status.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
• This will disable the BeltMinder feature if it is currently enabled. As
confirmation, the safety belt warning light will flash 4 times per
second for 3 seconds.
• This will enable the BeltMinder feature if it is currently disabled. As
second for 3 seconds, followed by 3 seconds with the light off, then
followed by the safety belt warning light flashing 4 times per second
for 3 seconds again.
5. After receiving confirmation, the deactivation/activation procedure is
complete
Old May 11, 2009 | 05:29 PM
tazo's Avatar
tazo
Autolock (if equipped)
This feature automatically locks all vehicle doors when the following
conditions are met:
• the ignition key is in the 4 (ON) position,
• all the doors are closed,
• the brake is pressed before reaching 5 mph (8 km/h), and
• the vehicle is traveling more than 5 mph (8 km/h).
Relock
The autolock feature repeats when the following conditions are met:
• the vehicle’s speed is less than 5 mph (8 km/h),
• any door is opened then closed while the ignition is in the 4 (ON)
position,
To deactivate/reactivate the autolock feature using the keypad
Your vehicle comes with the autolock feature activated. To
deactivate/reactivate this feature:
1. Ensure that the anti-theft system is not armed.
2. Turn the ignition to the 3 (OFF) position.
3. Close all the doors, liftgate and cargo doors.
4. Enter the 5-digit entry code.
5. Press and hold the 7 • 8. While holding the 7 • 8, press and release
the 3 • 4.
6. Release the 7 • 8.
The horn will chirp once when the system has been successfully
deactivated.
The horn will chirp twice (one short and one long chirp) when the
system has been successfully reactivated.
Old May 11, 2009 | 07:47 PM
12ozd's Avatar
12ozd
good luck
setup button ? drywall screw ? HUH ?
Old May 11, 2009 | 07:59 PM
MBman's Avatar
MBman
wow , thanks guys, will do
sgrol
6.7L Power Stroke Diesel
May 12, 2014 02:40 PM
nab101eg
2009 - 2014 F150
Jan 25, 2012 06:36 PM
maplelakeduckslayer
1997 - 2003 F150
Sep 10, 2007 05:06 PM
AWC
Aug 29, 2003 03:08 PM
