82 f-100 fan shroud
Old May 10, 2009 | 11:06 PM
82f-100's Avatar
82f-100
82 f-100 fan shroud
my shroud on my truck is broke but no one seems to make a fan shroud for a 1982 model.does anyone know if there is a difference in an 82 shroud and an 83-86 shroud?the shroud i need is for a 300 6cyl.
thanks
Old May 11, 2009 | 02:13 AM
longreins's Avatar
longreins
See if you can find the year span for a replacement radiator. Sorry, that is not really an answer, but hopefully a helpful thought.
Old May 11, 2009 | 04:00 AM
Trushietruck's Avatar
Trushietruck
make one
You can try getting a sheetmetal shop to make one for you. I made one for my '81 with a 351 and it works a treat. If you do remember to allow air flow between fan and radiator. i allowed 60 millimetres.
Old May 11, 2009 | 01:42 PM
FordNFishinLover's Avatar
FordNFishinLover
If i were you, id be just checking out the local junkyards. They are very simple to take off so it wouldnt take you long to pluck one off.
It shouldnt hurt anything to not have one on it right now. Just be careful.
Old May 11, 2009 | 05:05 PM
flyerskid716's Avatar
flyerskid716
only problem with not having a fan shroud is over heating and possibly chopping your fingers off when working on the engine....i lost a whole hand to it....jk...but i don't have one on my 85 f-150 and last summer it just ran hot alot cuz the radiator wasn't being kept cool....i ordered one off autopartswarehouse.com.....give them a shot
Old May 11, 2009 | 05:20 PM
uncle.stosh's Avatar
uncle.stosh
There are two types of shrouds.
One is for saddle mounted radiators and the other is for wing type radiators.
If your radiator is saddle mount (rubber cushions between radiator and core support and two metal clamps on top) then you need to replace it from a truck with the same setup.
Wing mounted radiators have two "wings" on the sides of the tanks that fit into channels on the radiator support and there are two 10mm bolts that hold it on the top. If you have that style, you need to find a donor truck with the same setup.
Old May 11, 2009 | 09:07 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
There's actually three different applicable ones for the 300-I6, according to the parts book.
Does your truck have a/c and or super cooling? In otherwords, does it have the wide, or narrow radiator?
A fan shroud from a 1980-1982 F-series trucks, and bronco, with the 300-I6 and A/C and/or Super Cooling should work for you. (Saddle Mount Radiator).
Can Be Marked on part with numbers:
EOTA-8146-AA
E2TA-8146-RA
1983-1986 use a different part to the 1980-1982. However, do not know if these are interchangeable for earlier 1980-1982 models.
Part Number
E3TZ-8146-E
The regular radiator, without a/c, are equipped with a smaller narrow radiator, and are equipped with a fan guard only that just protects the top. Also (Saddle Mount Radiator).
Marked:
E4TA-8A611-BA
Hope this helps.
Old May 11, 2009 | 09:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 82f-100
my shroud on my truck is broken, but no one seems to make a fan shroud for a 1982 model.
does anyone know if there is a difference in an 82 shroud and an 83-86 shroud? the shroud i need is for a 300 6 cyl.
E2TZ8146C .. Fan Shroud / E2TZ-8146-C replaces: EOTZ-8146-A / Obsolete
Fits: 1980/84 Bronco & F100/350 300 I-6 with: Standard Cooling, Xtra Cooling and A/C radiators.
1985 and later use different fan shrouds.
MARKED: On the upper left (drivers) side of the shroud: EOTA-8146-AA or E2TA-8146-RA (**)
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has ONE: 704-786-8139.
MIDPAC AUTO CENTER in Lihue Hawaii has ONE.
No other Ford Dealer or other obsolete parts vendor has any.
** Some of these shrouds will not have the 8146 portion of the ID number marked. Just EOTA-AA or E2TA-RA.
Ford part number source: 1980/89 Ford Light Truck Parts Catalog, 1991 final edition.
~ EDIT: E3TZ-8146-E .. Fan Shroud > > mentioned in post #7 fits 1983/89 Econolines ONLY! ~
Old May 11, 2009 | 10:44 PM
81-F-150-Explorer
Mine lists two different radiators, one for standard, and one for a/c and/or supercooling.
The Narrow standard radiator: 300/I6
Dimentions: 21 5/8 X 19 1/4 X 1 1/4 : 2 row : use 13 quarts, 8A-19549-A.
Uses fan guard, marked E4TA-8A611-BA.
The wider A/C and/or supercooling radiator: 300/I6
Dimentions: 27 1/2 X 19 1/4 X 1 1/4 : 2 row : uses 14 quarts, 8A-19549-A.
Uses Fan shroud, marked E2TA-8146-RA.
They also use two seperate top radiator hoses.
1984 paperback Edition (sucks)
Old May 11, 2009 | 10:48 PM
81-F-150-Explorer
Thanks for the correction. Worthless book now going in trashcan.
Old May 11, 2009 | 11:18 PM
NumberDummy
The fan guard is just a piece of sheet metal.
My 1991 version of the '80/89 catalog only lists that one shroud for all 1980/84 F100/350's & Bronco's with 300 I-6's, regardless of what type of cooling they had.
btw: Since Ford replaces 10's of 1000's of part numbers every year, one should never go by a part numbers prefix to ID what the part actually fits.
I see examples of that jazz here on FTE all the time.
Old May 12, 2009 | 02:08 AM
81-F-150-Explorer
Yeah, and I think some websites do the same thing. BOTP is one that has gross application errors. Great parts, just can't find them by application there.
I'm not sure about the fan guard being metal though. I remember them to be plastic, and has the Warning marks "CAUTION FAN - (and/or) Cooling System Not Equipped For A.C."
I'm also wondering how a fan shroud fits both size radiators when one is aproximately six inches smaller, than the other?
And thanks Bill for your time. I don't think you get thanked enough.
Old May 12, 2009 | 11:20 AM
bfbiker's Avatar
bfbiker
Talking fan shroud
On my 1990 e150 non a/c that I pulled the motor and trans or my 1985 F150 with a/c used the same fan shroud and the rads were diff van had a non overflow and truck has a over flow but bot shrouds have the same part numbers
just my 2 bits on it
Old May 12, 2009 | 02:28 PM
81-F-150-Explorer
I'm going to the wrecker today. I'll see if I can find the guard i'm talking about.
I measured the shroud on my engine, it's marked "EOTA-8146-AA" by the way, and it would stick 5.5 inches off the left side of the smaller radiator, and interfere with the smaller radiators tank on the left side, and basicly not fit.
Something is definately weird with this, I must admit.
Old Feb 9, 2026 | 06:28 PM
fatheroftwo's Avatar
fatheroftwo
Anyone still here on this subject? My 1980 no a/c 300 I6
has the # E0TA-8A611-AA, It is plastic and only a fan guard.
I am searching for one as well. There aren't any scrapyards within
3 hours of me.
