engine swap. wiring harness?
on
If you can find a mass air truck harness you'll have something that fits the body correctly and will plug right in to the motor and whatever EEC processor you get. But if you can't get one you'll have to do some editing on your existing I6 harness. For that use any MAF harness from a Mustang or Lincoln or T-bird, remove the injector and mair meter wires from it and insert them into your existing truck harness. The reason the car harness isn't a direct fit is because the computer is housed on the passenger side instead of the drivers side so it's assembled all backwords.
Hillcapper
19
09-19-2008 09:21 PM
oreodog
Electrical Systems/Wiring
15
06-05-2007 01:59 PM
Dalamatition
09-01-2005 04:51 AM
