painting Diff Cover ?'s
Old May 10, 2009 | 08:01 PM
Donny_D's Avatar
Donny_D
looking for suggestions/tips on best method and paint/primer for painting diff covers... i have spent the better part of the afternoon with a wire brush and my drill with a wire brush trying to clean them is it better to sandblast them? Or will the wire brush tactic work well enough? and as far as paint/primer goes any high temp krylon would work? thanks in advance!
Old May 10, 2009 | 08:24 PM
SuperDoodie's Avatar
SuperDoodie
I went to Ford last year when I did mine and bought a 2008 diff cover.. Its a finned verision and pretty decent for around $45-$50. Then if you don't like silver, you have a nice clean new cover to paint the color of your choice..
The bolt pattern is the same for our trucks, but you need different bolts.
Old May 10, 2009 | 08:26 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats what I did with mine. High heat paint, black, still looks good.
Old May 10, 2009 | 08:37 PM
7.3 Rocket's Avatar
7.3 Rocket
Edit: Nevermind. Thought you were a different person.
Old May 10, 2009 | 08:39 PM
Ponyboychris's Avatar
Ponyboychris
I have the 08 diff cover on the back and need to address the front. Probably do the sandblast and high heat paint on the front.
Old May 10, 2009 | 08:56 PM
F350-6's Avatar
F350-6
Longer bolts? Can you be more specific on the difference? That's a pretty good price on the cover. I've got to change my diff fluid in about 9k miles, so I might upgrade the cover at the same time.
Old May 10, 2009 | 09:05 PM
Ponyboychris
I don't remember the exact difference but yes, the bolts to attach the 08 diff cover are longer because the 08 cover is thicker. Diesel Manor sold the cover and bolts to me so it was not that much of problem for me. Sorry, should have taken pics but was too excited to get it on that night.
Old May 10, 2009 | 10:25 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I think Chris has a dually with a different rear end. I could be wrong. I have some pics in my gallery of my painted stock cover.
Old May 10, 2009 | 11:56 PM
SuperDoodie
You betcha!!
Here is some more detailed info..
Ford Part number: 8C3Z-4033-A
Bolts: Stainless hex head 5/16-18 x 1 1/4 inch long. Used stainless lock washer. Blue locktite to 20 ft/lbs. Seal with International Grey RTV sealant.
A few pics..
If you want to go black..
filthy6
Jun 4, 2016 12:44 PM
77beater150
Mar 11, 2014 12:14 PM
66 twin i
Paint & Bodywork
Dec 14, 2012 09:41 AM
headgoatroper
1947 and Older Ford Trucks
Mar 23, 2010 09:25 AM
blitzkraig56
Paint & Bodywork
Feb 26, 2003 06:21 AM
