Rattle can paint question
Old Jun 3, 2016 | 12:52 PM
filthy6's Avatar
filthy6
I had no choice but to sand my truck body parts to bare metal and prime them with rattle cans of DUPLICOLOR self etching automotive primer. Not an ideal situation but better than the house paint that was previously on there. I want to paint the inside of the fenders black and have the choice of DUPLICOLOR acrylic enamel or acrylic laquer, also rattle cans. After some googling I'm leaning toward the acrylic enamel. What say you? My long term goal would be to have an expert cover the primer and maybe even the black paint with an epoxy primer and then paint. Thoughts? Thanks.......
Old Jun 3, 2016 | 01:04 PM
oldmerc's Avatar
oldmerc
oldmerc
Inside the fenders use brush on rustoleum
Old Jun 3, 2016 | 03:17 PM
1956_F100's Avatar
1956_F100
Of those two choices the Acrylic Enamel will have a tougher finish. For the inside of the fenders a semi gloss or satin finish would look cleaner and better hide flaws.
Old Jun 3, 2016 | 04:30 PM
CBeav's Avatar
CBeav
You can buy POR 15 4oz cans for about $8/can (six pack) on Amazon. One or two 4oz cans would probably do the inside of a fender and do a heckuva lot more good, protection-wise, than any rattle can paint. Sometimes you have to consider value vs. false economy.
Old Jun 3, 2016 | 04:37 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
For the inside of the fenders your best bet would be a paintable rubberized undercoating or a roll on or rattle can bedliner. Both would be a lot better for protection from rock chips and the like.
Old Jun 3, 2016 | 04:40 PM
JakRak's Avatar
JakRak
You mentioned that you might want to have it professional sprayed at some later date, so I would check with a reputable body man/body shop to see if they can still paint over rattle can primer and some sort of topcoat. Even though it's inside the fenders, they still might want to strip that stuff down to bare metal for a new color coat.
Old Jun 4, 2016 | 09:43 AM
Mr. Ed's Avatar
Mr. Ed
Mt personal choice is acrylic enamel. Laquer has tendency to wrinkle previous coats of put on to close to eh application of previous coats or too heavy of a coat.
Later!
Mr. Ed
Old Jun 4, 2016 | 12:34 PM
filthy6's Avatar
filthy6
Thanks for the responses. I am trying to do as little permanent damage as I can. Will probably hold off on the more durable and likely harder to remove undercoatings until I find out if I did a good enough job getting through the previous layers of paint and rust. As the temperature approaches 107* I can tell the quality of my work is declining.
Old Jun 4, 2016 | 12:44 PM
filthy6's Avatar
filthy6
I agree. I was hoping someone on here might have had experience of color coating or re-priming and then color coating over rattle can primer. It would not be a metallic show truck rather more of the old school look. The primer is kind of a military green and who knows, it may stay that way indefinitely.
1950FordF1
Feb 7, 2014 08:46 AM
FortyNiner
Apr 29, 2013 08:35 AM
Kalve
May 22, 2010 07:39 PM
hoxiii
Paint & Bodywork
Apr 10, 2007 09:23 AM
MP1
Appearance & Dress-Up
May 23, 2005 06:45 AM
