Friend of mines 05 350 keeps the ABS light on all the time. Hooked my AE up to it and it's throwing the code:
C1175 Speed Wheel Sensor LR Input circut failure. Antilock brake/traction control.
Question is their isn't a sensor on the left rear??? Would it just be the speed sensor? Ford replaced it once under warranty, but 3 months later (out of warranty of course) the light came back on.
Also their was a code: B1352 Ignition key in circut failure, instrument cluster. The dinger is disconnected, could this be the cause?
