Sponsored by: Real Truck
Possibly a bearing going already?
Old May 10, 2009 | 09:57 AM
08tolleya's Avatar
08tolleya
I have a 2008 ford f 250 5.4 L triton. Makes a humming noise from the right side of the truck when I am turning right at about 20-45 mph. I only have 12500 miles on it, and Would that still be under warrenty I hope?
Old May 10, 2009 | 10:50 AM
BareBones's Avatar
BareBones
I'd think so. My warranty in 2005 was 36,000 miles or 3 years. It could also be power steering, too.
Old May 10, 2009 | 10:51 AM
BareBones's Avatar
BareBones
Try turning corners with the engine revs above idle.
Old May 10, 2009 | 11:02 AM
08tolleya's Avatar
08tolleya
yea when I accel. around the corners, you can hear the humming get faster then at highway speeds it goes away. It seems to happen at low speeds, and only turning right.
Old May 10, 2009 | 06:56 PM
BareBones's Avatar
BareBones
As long as the problem is one that you can easily demonstrate to the dealership, just take it in and let them work the issue. While you're under warranty you really don't have to worry about it.....
Old May 10, 2009 | 07:00 PM
08tolleya's Avatar
08tolleya
Ok..any advice on how to demonstrate it to them? Take a service guy for a drive in it?
Old May 10, 2009 | 07:01 PM
Fordfanatic4life's Avatar
Fordfanatic4life
right side wheel bearings maybe ???
whateva it is warrenty will look after it..
just take it in and get it sorted..
Old May 11, 2009 | 01:14 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is your right front hub locked?
Old May 11, 2009 | 09:15 PM
08tolleya's Avatar
08tolleya
No its not locked. Its starting to drive me crazy.. I cannot figure out what it is.
