14PSI Boost ??
Old May 10, 2009 | 05:19 AM
ChunderDownUnder's Avatar
ChunderDownUnder
14PSI Boost ??
Well I took of the IC pipes and spider and cleaned up all the boots.
Compressor wheel is tight no play either way
Polished the pipes and did the foil delete
The up pipes show no sign of leak. Oh i also checked the gauge T piece for leaks.
So, Im getting 5psi up to 2000 rpm. 5-10psi from 2000 - 2500 rpm
and a whopping 14psi at 3000 rpm.
what do I look for next. ???
Old May 10, 2009 | 05:21 AM
ron's power stroke's Avatar
ron's power stroke
to get better answers you should start a new thread..
but since the has started..i would build a leek detector like this one and check for boost leeks
http://www.dieselsite.com/index.asp?...ROD&ProdID=607
then i would look at the wastgate to make sure it isnt stuck open...
Old May 10, 2009 | 06:23 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
You and me both brother.....I tried to look for my boost issue before I left for Iraq but never found it....if you find ur problem let us know!!!
Only thing I hadnt started was my bellowed up-pipes upgrade....maybe check ur up-pipes for leaks.
Old May 10, 2009 | 06:40 AM
ron's power stroke
ok..some one is messing with me or i drank too much beer last night..lol i could swear i posted this in another thread..
Old May 10, 2009 | 06:43 AM
megawatt00's Avatar
megawatt00
It was the beer Ron...
Old May 10, 2009 | 06:45 AM
ron's power stroke
i should have guess you was up early this morning keeping me on my toes...l
Old May 10, 2009 | 06:52 AM
megawatt00's Avatar
megawatt00
You were right it needed to be moved into this thread. The OP posted his question in the other thread by accident. Didn't mean to mess with your mind this early in the am.
Old May 10, 2009 | 07:01 AM
riverrat41's Avatar
riverrat41
Wink
We all appreciate what you did for us and our country in Iraq
GLad you are back safely!
Old May 10, 2009 | 08:06 AM
danskool's Avatar
danskool
Go Bills !
I have done my boots. Leaker detecter. My compressor wheel looks good like yours @ awsome... WOT is 16. Red line unpluged and capped. 17. I used to get 15/16 untill i took off my muffler and 6637. No chips either no exhaust leaks.
If you find a way to get it up without a chip. Let me know.. I spent allot of time to get that 20psi. I guess the dptuner will have to do it.
Old May 11, 2009 | 05:36 AM
ChunderDownUnder
So whats the stock PSI output on these things..
Im using the Edge Evolution programmer set on tow mode to get these outstanding figures
Old May 11, 2009 | 07:21 AM
Izzy351's Avatar
Izzy351
If you're only getting 14 with tunes, look for leaks. I used to do 16-18 on my stock tune with my stock turbo. Could be the up-pipes, boots, or at the turbo outlet, or maybe even cracked I/C. Since you just had your boots off for cleaning, I assume everything is tight in that area, right?
Old May 11, 2009 | 08:28 AM
DieselCamper01's Avatar
DieselCamper01
I have no leaks in my system and the best I have seen is 15 psi. Thats about it on a stock truck. And I have a Superchips on that I did not know about until last week. lol
No up pipe leaks and no boost leak that I can find or hear.
Old May 12, 2009 | 03:00 AM
ChunderDownUnder
Well, I dont know how I missed it
but here is the problem
Im getting a boost leak detector made up as we speak, just to make sure there is no other surprises.
What bugs me is, my 4" should arrive this week from your side of the world.
The uppies would of been good to do at the same time.
What are my options regarding the up pipes.
I dont like doing jobs half arsed.
Old May 12, 2009 | 03:20 AM
ron's power stroke
do it once..do it right..call Clay about some bellow up pipes.no donuts to go bad,,
you can do the donuts for about 20 bucks..but you will be doing them again in a year or so..
Old May 12, 2009 | 03:24 AM
Visseroth's Avatar
Visseroth
Just be sure you're not a early 99. If you are then up pipe replacement isn't so nice!!!
I have a simular leak, I can't replace my up pipes yet but will patch it tell I can replace the up pipes, turbo, intercooler, stuff like that. I think about that time I'll see what clay is up to and pay him a visit over a weekend or what ever and see if he is willing to give me a hand with my beast
