Sponsored by: Real Truck
interior trailer lights not working
Old May 9, 2009 | 10:50 PM
Simoncx's Avatar
Simoncx
I have a 05 powerstroke with towcommand and for some reason the interior trailer lights don't work unless the truck is on. I bought the trailer new in Feb but when I checked the truck was running, the trailer has a wet cell battery for the breakaway but I figured the lights would work off that even if unhooked. Any help?
Old May 9, 2009 | 10:56 PM
Monsta's Avatar
Monsta
Sit. Stay.
The lights in my trailers never worked unless the ignition was at least turn to ON. I'm sure there is a simple work around that someone will post.
Old May 10, 2009 | 12:02 AM
Mud Doc's Avatar
Mud Doc
I don't think the breakaway battery is used for anything but just that--activating the trailer brakes when the pin is pulled. You wouldn't want to drain that battery in case it is ever needed. You would have to have a separate 12-volt battery wired in to the charge circuit of the truck and to the light system--then you would have lights w/o the truck. I have never seen a trailer with interior lights that didn't have a regular 12-volt battery, but I sure ain't seen them all.
Old May 10, 2009 | 08:46 AM
Simoncx's Avatar
Simoncx
Thanks I really wasn't sure if it was suppose to run off that battery or not. I really don't use the interior lights just wanted to find out if thats hows it's suppose to be. The battery is a 12v but it is small, probably the size like a garden tactor battery.
170Workhorse
Feb 16, 2017 09:26 PM
Fergs
All Things Towing
Sep 14, 2015 08:26 PM
gauldin71
All Things Towing
Jun 26, 2015 06:47 PM
stoverdr
Jun 11, 2015 02:55 PM
Icthus in AK
May 23, 2015 07:20 AM
