well im just looking for a bit of a better spark. i had some cheap duralasts on my old truck which woke it up a ton. so im just looking for a little bit of that. im wishing i would've just got some duralasts.
heck you can say that for half the brands that are made. but i've never had a problem with ANY duralast part i or my dad have ever bought. and thats a lot of duralast parts. autozone if at all possible is the only place we buy from.
YOu're lucky then. Every duralast ignition part I EVER bought was bad. It might not have FAILED entirely, but it definitely wasn't a good part. If you want GOOD wires go to Advance and get the motorcraft wires. They are the same wires your truck came with, and no messing with putting boots on them. How often do you have to replace your ignition parts? I found that with the cheaper (wells, duracraft/duralast) part that I was replacing them once a year to cure a rough idle and miss. I go the motorcraft wires from advance and never had to replace them.
