instructions for accel plug wires
Old May 9, 2009 | 11:39 AM
nflfreak43's Avatar
nflfreak43
plain and simple suck. im not the bwest with assembling electrical things like plug wires any help will be appreciated.
Old May 9, 2009 | 04:08 PM
*2fords*'s Avatar
*2fords*
I ran into the same problem. I found it best to crimp the ends on then slide the boots over the ends. I don't remember if they provided lube or not, but it helps to use it. Vasaline will work if they didn't. I didn't cut my wire to lenght, as I was nervous about doing damage to the internal wire. but my truck ran fine till I blew up the engine a few years later.
Old May 10, 2009 | 06:42 PM
nflfreak43's Avatar
nflfreak43
yeah i just gotta have someone give me a picture or something. or a very very very detailed explanaition. dang i feel stupid.
Old May 10, 2009 | 07:16 PM
muddyford911's Avatar
muddyford911
its easy, just cut the wire to length. strip the insulation back about a half inch. fold the metal wire over and crimp the end on. be sure you crimp it tight though. and use dialectric grease to lube it.
Old May 10, 2009 | 07:37 PM
nflfreak43's Avatar
nflfreak43
hold on i'll be posting pictures of the different pieces they sent me. i just need to know which of which is should use.
Old May 10, 2009 | 07:54 PM
nflfreak43's Avatar
nflfreak43
ok here are the pictures i have questions about. im feeling dumb bout this.
#1 spark plug boots
<a href="http://s175.photobucket.com/albums/w156/nflfreak43/?action=view&current=0510091926a.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w156/nflfreak43/0510091926a.jpg" border="0" alt="Photobucket"></a>
#2 fun..... which one should i use? How do i get the metal inside the ruber boots? these are the distributor cap end.
<a href="http://s175.photobucket.com/albums/w156/nflfreak43/?action=view&current=0510091933a.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w156/nflfreak43/0510091933a.jpg" border="0" alt="Photobucket"></a>
#3 how am i supposed to fold this??
<a href="http://s175.photobucket.com/albums/w156/nflfreak43/?action=view&current=0510091953a.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w156/nflfreak43/0510091953a.jpg" border="0" alt="Photobucket"></a>
Old May 10, 2009 | 08:51 PM
muddyford911
pic #1 spark plug boots, go on the spark plug
pic #2 use the silver ones with the smaller boot
pic #3 fold that wire back so that it faces the distributor cap side and clamp the silver piece on. but make sure you have good contact between the silver piece and the wire
Old May 11, 2009 | 01:00 AM
nflfreak43's Avatar
nflfreak43
well obviously i dont even know why i posted that pic but how the heck am i supposed to get those metal pieces to fit in those boots. and why use the small ones?
Old May 11, 2009 | 12:36 PM
muddyford911
the larger gold terminals are for HEI distributors. Just clamp the silver terminals around the wire, and push the silver terminals through the boot. sorta hard to explain, but simple to do. hope that helps
Old May 11, 2009 | 01:42 PM
nflfreak43's Avatar
nflfreak43
but how do i fold the wire?
Old May 11, 2009 | 04:25 PM
nflfreak43's Avatar
nflfreak43
should i fold it over kinda like this......
<a href="http://s175.photobucket.com/albums/w156/nflfreak43/?action=view&current=0511091609a.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w156/nflfreak43/0511091609a.jpg" border="0" alt="Photobucket"></a>
or should i slide it in like this?
<a href="http://s175.photobucket.com/albums/w156/nflfreak43/?action=view&current=0511091202a.jpg" target="_blank"><img src="http://i175.photobucket.com/albums/w156/nflfreak43/0511091202a.jpg" border="0" alt="Photobucket"></a>
Old May 11, 2009 | 06:22 PM
1966Tbird's Avatar
1966Tbird
the first way is correct
Old May 11, 2009 | 07:20 PM
nflfreak43's Avatar
nflfreak43
yeah i finally figured that out. so now another problem. i cant get the stupid boots on all the way. and running out of that lube stuff. won't petroleum jelly work?
Old May 11, 2009 | 10:26 PM
1966Tbird's Avatar
1966Tbird
yes petroleum jelly will work
Old May 12, 2009 | 09:26 AM
nflfreak43's Avatar
nflfreak43
alright day 2 of trying to put even 1 of these plug wires together. these things better be beastly if they are this hard to put together.
