Idle Fluctuate
Old May 8, 2009 | 06:01 PM
alstieg's Avatar
alstieg
Idle Fluctuate
when my truck gets warmed up and have driven it for 20 miles i'll put it in park and let it run and the rpms will go up 100 for 15 sec then come back down. At first i thought it was because the AC was kicking on and off but I turned that off and still the same. It also seems like i have to roll it over a lot longer to get it started. I was questioning my IPR valve. I've got 262k on the truck. Is this going bad or in need of cleaning?
Old May 8, 2009 | 06:41 PM
Pocket's Avatar
Pocket
IPR could be a problem. It can cause weird idle issues.
Old May 8, 2009 | 09:08 PM
alstieg's Avatar
alstieg
Should I buy one from ebay or should i get a o ring kit for it?
Old May 8, 2009 | 09:18 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
See this LINK. It a disassebly and cleaning of the IPR.
You can get the IPR o-rings HERE
Old May 8, 2009 | 09:22 PM
F350-6's Avatar
F350-6
Hard to say. Some have had luck just replacing o-rings or doing the rebuild process, others have had to buy a new IPR.
nerdpcr
Sep 13, 2014 12:01 PM
mudbug04
Apr 27, 2011 12:39 PM
morimoto_87
20
Feb 3, 2010 09:56 PM
dwhisenant
Feb 17, 2009 10:37 AM
theologian
New Member Introductions
Aug 18, 2003 09:54 PM
