P1316 Attack!!
Old Apr 25, 2011 | 12:46 PM
mudbug04's Avatar
mudbug04
P1316 Attack!!
guys i cant get my truck in the shop until in the morning and i have a 42.5 mile drive to work every day with no spare vehicle, am i going to screw anything up attempting to make it home and back to work in the morning? It acted up on me this morning, i shut it off and waited a couple minutes and fired it back up and it ran perfect.
Any advice please....
Old Apr 25, 2011 | 02:52 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
What do you mean by "acted up" exactly? Did it stall/stumble on you, lose power, jerk back & forth or side-to-side, randomly belch 30' flames....?
Old Apr 25, 2011 | 03:32 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Does your SES light come on and the truck feels like it falls flat on it's face running on only 4 cylinders? Then the light goes off and power is restored? If so, then you might have the same issue I had a short while ago which was a burnt center pin in the UVCH. The symptoms would come and go.
If you suspect a burnt center pin and want to check your harness then keep an eye on your EGT gauge next time the symptoms occur. Assuming your probe is pre-turbo and in the driver's side exhaust manifold.....then high EGTs during SES light points to a fault in your passenger side. Low EGTs during SES light points to a fault in your driver's side. Pull whichever valve cover you suspect and remove the gasket and harness completely. It's very difficult (if not impossible) to see the burnt terminals with the parts in place. You have to pull them out and get a good look with adequate lighting to see the issue.
If you find something that looks like this, then order a replacement set from RiffRaff. If you need your truck while you wait for the parts, then you can use a small pipe cleaner on the harness connector and some emery cloth on the gasket pin to clean it up enough to get you buy for a week or two. It will happen again so don't just clean it and forget about replacing the parts because the symptoms will return.
Riffraff Diesel: Ford Valve Cover Gaskets
Old Apr 25, 2011 | 04:48 PM
clintbonnie's Avatar
clintbonnie
What Greg says.. X2
Old Apr 27, 2011 | 12:39 PM
mudbug04's Avatar
mudbug04
well this cost me a good penny, it wouldnt run after lunch yesterday so i had to get a tow truck to take it to Ford... WHILE it was there they also concluded that i had a busted fuel line (which i went to check it out and a big negative on that "busted fuel line" ) the boots on the lower turbo tubes were about gone so they replaced those, the harness under the valve cover and the gasket for it (passenger side), and my ipc was going out again (which i inspected before giving the go ahead) so needless to say the ol garage got me again. $1400 later me and the ol lady decided that a 3rd vehicle was necessary so we are going car shopping this weekend for a vehicle "just to put miles on" so i can work on my own junk instead of giving my money to the stealership. Thanks for the help anyways guys, yall are great !
octaneforce
Jul 29, 2011 04:13 PM
04F-250mark
Mar 22, 2010 07:02 PM
Paul1212
Dec 6, 2006 05:58 PM
93tankus
18
Nov 21, 2006 09:54 PM
goodie350
Utah Chapter
Jan 17, 2006 01:52 PM
