Biggest tire size on stock wheels
Old 05-08-2009, 04:54 PM
07fordfx4's Avatar
07fordfx4
07fordfx4 is offline
whats the biggest tire size you guys are running on your stock wheels, I have the FX4 wheels which are 18X7.5, I'm currently running BFGoodrich All-Terrains 285/65R18. Im looking for something a bit more "Beefy"
Pics would be nice
Thanks
Old 05-09-2009, 06:15 AM
Jim Allen's Avatar
Jim Allen
Jim Allen is offline
Look at the approved rim width dimensions on the tire spec sheet and stay within that if you want the tire to work as designed. I run 285/70R17 on my truck and that's right at the outer edge of the specification for a 7.5 inch wheel. When you go outside that rim width spec, you can end up with handling and tire wear issues. I think you are at the upper max of tire width right now for the stock rims, at least for the few tires I looked up. You may be able to go to a taller tire, a 70 or 75 profile, but no wider. Save your pennies for new rims, then upgrade.
Old 05-09-2009, 11:50 AM
07fordfx4's Avatar
07fordfx4
Thanks Jim, well explained!!
Old 05-11-2009, 09:18 AM
jsoko's Avatar
jsoko
jsoko is offline
remember that when you go with a taller tire, things change
speedo
gear ratio ( as in tall tire makes your 3.73 LS feel like a 3.08)
slower take off speed
less tow ability (as in makes engine & trans work harder)
but everbody is going that route, very few change the gears , cause of the $$$$ involved
I like the "beefy look", a programer would help with speedo & give a little more back.
try to get someone to let you drive their Truck that has tall tires without any mods & you'll see what I mean
Good Luck & choose Wisely
Old 05-11-2009, 10:39 AM
07fordfx4's Avatar
07fordfx4
thanks JSOKO, I am aware of all that changes with going with bigger tires. So my decision came to be just hold off and save a bit more and go with a gear change all at the same time(It will probably be a while now LOL)
thanks again
Old 05-11-2009, 11:30 AM
jsoko's Avatar
jsoko
jsoko is offline
thanks again
a gear change, you have to do both axles will cost around A grand or more
4.56 would be good for a tire size of 33"-35"
Old 05-11-2009, 11:50 AM
07fordfx4's Avatar
07fordfx4
I got an estimate at a near 4X4 shop around hear and they told me $1500 out the door,
for 4.56. I want to go with 35's
Old 05-11-2009, 02:36 PM
spatts's Avatar
spatts
spatts is offline
315/70/R17 = 35's on 17's
Bhart1360
6.7L Power Stroke Diesel
03-30-2013 11:52 PM
the_auto_tech
12-10-2012 09:56 PM
allenohara
Offroad & 4x4
10-19-2007 09:39 PM
WILLIAM HORNSEY
2004 - 2008 F150
03-06-2006 05:55 AM
broncopimpservice
Bronco II
04-08-2002 08:08 PM
Quick Reply: Biggest tire size on stock wheels
