closed knuckle front end
Old Aug 18, 2002 | 06:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Old Aug 31, 2002 | 09:00 AM
wickman's Avatar
wickman
I have a 76 f250 4x4 with a d44hd front end,it is of the closed knuckle type. What years were these used? also why are they so bad,i mean this is all ive heard,and can or even should switch them to something else? Thanks y,all!
Old Aug 31, 2002 | 12:52 PM
karljay's Avatar
karljay
The closed knuckle was used from about 77 back and got a bad rap because of sealing. The seal tend to leak and allow water in and that will ruin everything. The open style is simple and a bit easier to maintain.
I just rebuilt my D44 on a 73 F250 and the seal kits were $12 each and the job wasn't that hard. I filled the knuckle with blue trailer greese that's water resistant and it's working great. The seals don't work too well with oil so most use a combo of greese and oil or straight oil.
The only real down side is that if you get water in there you have to clean it out and that takes a bit of work. I don't think it's worthwhile to replace them just because they require a bit more work.
Old Aug 31, 2002 | 03:32 PM
wickman's Avatar
wickman
Thanks for the info, can you get this seal kit at local auto store? I have a Clymer shop manuel and it doesn't go into detail on this(or much else for that matter). Can you or anyone else recomend a good manual for my 76 f250 4x4? Thanks much
Old Aug 31, 2002 | 04:28 PM
alpo23's Avatar
alpo23
Sorry, but if it is a 1976 truck it would have had a low pinion OPEN knuckle D-44. So it looks like someone changed axles on you before you bought it.:-(
1975 was the last year for closed knuckle. '76-'77 1/2 were open knuckle with disc brakes.
If your D-44 is indeed a HD. then it will have the large external hubs with 6 each 3/8" cap screws holding the assemble together.
Good luck.
Eric
Old Aug 31, 2002 | 08:13 PM
wickman's Avatar
wickman
Thanks for the info,you were right it is open nuckle.Is this a good heavy front end?
Old Aug 31, 2002 | 08:59 PM
fatdaddy's Avatar
fatdaddy
If you can see the u-joint its an open knuckle-------the d44 , HD axle is characterized by large hubs about 4 inches or so in diameter---I just measured mine -----you've got a very tough axle on your truck in my opinion.....fd
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
Roachfood
Mar 11, 2002 10:21 PM
