not permanent power loss, unless you break something which is likely at that high of rpm. the engine just basically loses power, you let out of the gas so the revs get down and your engine is back to normal however sustained amounts of time at high rpms with floating valves can cause serious problems.
Yeah, I would think so, as easy as it reaches 4K. So floated valves = permentant power loss?
If it idles smoothly-no bent valves. Good to go.
I drove a telephone truck with the 4.9 years ago and if floating valves would hurt it-I would have found out about it. But I wouldnt suggest doing this. Just on fleet vehicles.
The computer cant shut the engine RPM down when the driver downshifts. The computer can shut the engine down when upshifting-and it does it by cutting out the ignition. This way of shutting down the engine doesn't work when the driver downshifts-the engine can become a bomb all by itself-ignition or no ignition.
A bad excessively high speed downshift could killl an engine-or the driver may get away with it for several times and not know that he is overrevving the engine-because Ford didnt include a redline on the factory tach.
This is more likely to occur in mountainous terrain-where the driver is trying to use engine compression and no throttle to control the vehicle speed doing down the mountain.
Anyone that have operated a high performance motorcyle knows what a rev limiter does. Or low performance motorcycle for that matter. My old ST1100 limiter operated all of the time---very smooth engine and flat horsepower curve and low output (100 HP) meant that I was hitting it all of the time on Interstate onramps.
...I didn't know that the rev limiter wouldn't work on a down shift . And i don't know why fords don't have red lines on there tachs . I have an 04 ..5.4 & it has no red line . I got rid of the factory limiter on my 95 302 . I use msd ignition with a soft touch limiter that randomly drops cylinders & works great for me i just set it a little higher than my shift points & use a tach with a shift light so i never hit it unless i screw up . Lew
when i pin it it seems like it goes too high to shift, since there is a bit of time where it is increasing in rpms but not movin any faster haha
might be time for a fluid change, it sounds like shes slippin a little bit. but ive yet to drive an e40d that doesnt seem to slip alot and ive driven/ridden in about half a dozen. it does the same on my truck and ive been driving it like that for 2 years so i guess there just a little sloppy.
yeahh i mean it isnt too long after but it was kinda funny i pinned it the other day and it was like there was like a few seconds before it shifted that i didnt go any faster haha
haha thats what this one guy said, every now and then it shifts a bit hard and he was like put up with it its fine, and well if my tranny blows out then its a perfect oppertunity to drop in a 5.0 with a 5 speed
yup. when my tranny gets hot, it shifts so hard going in reverse or whatever that it feels like something is going to break. I really want to have my tranny rebuilt with a very firm shift kit. I honestly think my truck has the power to bark the tires going in second if the tranny wasn't so sloppy. when I had OE sized tires, after my gear ratio change my tranny did shift firm.. it was really nice.
