Sponsored by: Auxito
Interesting ABS Problem
Old May 7, 2009 | 05:38 PM
pbsterling's Avatar
pbsterling
In the last couple of days I have been experiencing a problem with my ABS. When slow down and turn, the ABS engages while braking. It does not do it while braking on a straight away. I'm guessing a Front ABS sensor problem or wiring leading to it. Any suggestions?
1998 F-150 4.6 4x2
Thanks in advance
pbsterling
Old May 7, 2009 | 08:29 PM
chaser1602's Avatar
chaser1602
You mean the light comes on?
Old May 8, 2009 | 08:44 AM
pbsterling's Avatar
pbsterling
No the ABS light is off but the system engages - pulsating brake pedal - every time I apply the brakes while cornering.
Old May 12, 2009 | 11:02 PM
bada$$f150's Avatar
bada$$f150
mine did the same thing but the light came on, i just took the abs fuse (fuse #25 under dash) out and it quit. A few days later i put the fuse back in and it was still ok. Maybe this will work for you.
Old Nov 17, 2009 | 11:43 AM
pbsterling's Avatar
pbsterling
I finally replaced the front ABS wheel sensors. Problem gone.
Another question - Is there an easy way to determine if my truck has 4 wheel ABS or just 2 wheel ABS?
Old Nov 17, 2009 | 06:25 PM
DJPRacer58's Avatar
DJPRacer58
if u have sensors on the front u got 4 wheel abs. 2 wheel abs is just the sensor in the rear pumpkin
Old Nov 25, 2009 | 10:19 AM
paul64's Avatar
paul64
How do you know which front ABS sensor it is.
I went to the ford dealer here in canada and they are $250 each side.
The whole hub with the sensor is $330.
What a crime eh! (LOL)
I have the same problem. No ABS light comes on but it activates at 10MPH
Old Nov 25, 2009 | 02:17 PM
EmmEff's Avatar
EmmEff
My truck has just started doing the same thing... I'm thinking of just yanking the fuse and saying "bye" to ABS.
The sensor is in the diff?
I've noticed lately that my diff looks like it's leaking. I wonder if this is related?
Old Nov 25, 2009 | 08:07 PM
eallanboggs's Avatar
eallanboggs
How does ABS get activated? When vehicle speed excedes wheel speed(skidding) ABS is activated to get the wheels spinning at the same speed the vehicle is moving. The wheel sensors are the key to the whole operation. You can monitor the sensors with a low current clamp on probe.
Old Nov 25, 2009 | 11:16 PM
steve(ill)'s Avatar
steve(ill)
the rear sensor is on top of the differential. it points at a big thin gear bolted to the ring gear. it counts teeth as the gear turns and computer compares speed to the front wheels.
Old Nov 26, 2009 | 07:24 AM
paul64's Avatar
paul64
I already changed the rear sensor and that did not fix it. $28
It has to be 1 of the 2 front sensors but I am not able to determine which one. $230 each
The dealer wants $100 just to diagnose it and tell me which one it is.
I just pulled the fuse as well.
Old Nov 26, 2009 | 12:08 PM
eallanboggs
Use a low current clamp on amprobe connected to your DVOM. You spin the wheel with probe clamped onto the sense line. You should see an output proportional to the speed the wheel is spinning. This will tell you which sensor needs to be replaced.
351Cleveland C4
1983 - 2012 Ranger & B-Series
Jul 1, 2014 07:28 AM
delostruck
Nov 24, 2006 06:50 PM
Repsher
17
Sep 22, 2005 11:29 AM
nocal
Jun 13, 2004 06:48 PM
crazyfoolreal
May 25, 2004 08:43 AM
