2000 4x4 abs
Old Nov 21, 2006 | 04:35 AM
delostruck's Avatar
delostruck
Question 2000 4x4 abs
i have a 2000 4x4 supercab 4.0 L when coming to a slow stop the abs is kicking in i disconected the abs at the pump and the problem went away the brakes work perfect but when i plug the abs pump back in the problem comes back i am guessing that there is something wrong with one of the speed sensors but not sure if anyone has had this problem and fixed it let me know thanks.
Old Nov 24, 2006 | 06:50 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
It sure sounds like you have a sensor dropping out. You'll need to install a scanner that's capable of reading each wheel speed.. then have someone else drive it while you read the scanner.. it should be fairly obvious.
j3scott3!
Sep 22, 2011 03:27 PM
stecz
Oct 10, 2010 04:12 PM
floor monkey
Jun 17, 2009 07:50 AM
cratemotor
17
Dec 3, 2007 12:23 PM
jayhawkfan
Feb 19, 2004 03:29 PM
