voltage regulator problem
Old May 6, 2009 | 07:45 PM
trailblazer28333's Avatar
trailblazer28333
here's what i've run into... i took three trucks and made one. body and rear half of frame is a 75 supercab 2x4 that had a 429 in it, front part of frame and tranny and 390 came off of my 76 4x4 that burnt(interior complete loss, exterior right side paint and tires.... all wiring under hood was intact and unharmed) and the axles came out of a 78. the 75 supercab wiring under the hood was a nightmare, it had more wires around the starter solenoid then the other 2 trucks combined. so with a whole lot of help from a pair of side cutters and a haynes manual wiring schematic i was able to get it running only to find out that it didn't charge the battery. so back to the haynes manual and all the wiring harness's from all 3 trucks... found the problem and its charging now. but it fluxuates between 14 and 18 volts, which causes the headlights and dashlights to look like a disco ball. tried all 3 voltage reg's, all do the same. i know that the one from my 76 was good.
does anyone know what could be causing this?
Old May 6, 2009 | 08:05 PM
Jermafenser's Avatar
Jermafenser
Whenever you have an electrical problems...check the ground first.
Since it's a hillbilly deluxe, did you remember to install ground straps afterwards?
Old May 6, 2009 | 08:17 PM
trailblazer28333
yes the body is grounded to motor and the ground cable for batter is hooked to motor
fmc400's Avatar
fmc400
MSEE
Run a jumper wire from the negative battery post to one of the regulator mounting bolts and see if that changes anything. Does this truck have an ammeter or an ALT light? We need to ohm out the harness.
Old May 6, 2009 | 08:21 PM
trailblazer28333
it has meter in the instrument cluster (which works suprisingly enough) but i had installed an aftermarket voltage guage as a precaution
tbirdscott
Electrical Systems/Wiring
13
May 30, 2018 12:16 AM
flashover604
Jul 2, 2009 11:32 AM
Chuck14
Feb 23, 2009 04:41 PM
fenix1
May 21, 2008 09:56 PM
duback66
Feb 17, 2005 11:04 PM
