Modular V10 (6.8l)
Replacing idle air control valve
Old May 6, 2009 | 05:56 AM
stoveguysford's Avatar
stoveguysford
How much of a job is it to change my IAC valve on my 99 f350 v10. Its the next step in my quest for curing a rough idle/skip problem. My mechanic is on spring break and I can make the time. I'm not a car mechanic but I know my way around my toolbox. Any advice would be terrific.
Old May 6, 2009 | 07:38 AM
manglass's Avatar
manglass
It's basically 2 bolts and one wire connector. On my excursion, it's on the back of the throttle body so it's not convenient to reach but should be accessible after removing whatever cover, hoses, etc are in the way. Careful, some of the hoses are coolant hoses so try not to disconnect those. If there is a fault code set, you'll want to erase it with a scan tool, or by disconnecting the battery, or removing the appropriate fuse. If you discon. the battery or pull the fuse, the ecm will have to re-learn so it may run different at first.
"Rough idle/skip" sounds more like an ignition problem though. IAC valve usually causes a stalling problem.
Lou Manglass
Old May 11, 2009 | 02:05 PM
mikesmayhem's Avatar
mikesmayhem
I agree with manglass that when the IAC goes bad it usually results in the vehicle stalling.
Old May 21, 2009 | 11:39 PM
Bananarama's Avatar
Bananarama
my Iac was causing an issue with idle. It would...surge
Old May 22, 2009 | 03:37 AM
Move over I'm coming's Avatar
I agree with manglass, you probably have a bad COP/coil or a spark plug issue.
Have you ever done a tune-up on your truck?
bronco35193
General Automotive Discussion
Jun 4, 2015 11:55 PM
rockpile
15
Jul 18, 2011 11:23 PM
dd6464
Modular V10 (6.8l)
Nov 30, 2008 05:45 PM
molinsky
Aug 29, 2007 07:28 PM
omni
16
Aug 4, 2004 03:00 PM
