Engine Pinging
Old May 5, 2009 | 10:14 PM
Sandblaster01's Avatar
Sandblaster01
Engine Pinging
I screwed up and need help to see how bad I did and what I need to fix it.
I was in a great hurry when I changed my oil last time and got too much oil in the engine. I drove it that way a bit until I could get it drained down to 15 quarts.
Now I have an engine that is blowing a great amount of smoke out the exhaust and is clicking or pinging a lot. It continues even after I I got the right amount of oil in the engine.
What may I have done and what will I probably have to do to get it fixed?
Signed: a mechanic want-to-be that shouldn't-be.
Old May 5, 2009 | 10:18 PM
clux's Avatar
clux
Have you got some idea of how much of a overfill you're talking about here?
Old May 6, 2009 | 09:12 AM
Sandblaster01
Probably about a short quart.
Old May 6, 2009 | 09:48 AM
Izzy351's Avatar
Izzy351
1 extra quart isn't the culprit here... Something else is wrong.
Old May 6, 2009 | 09:52 AM
Kwikkordead's Avatar
Kwikkordead
What kind of oil did you put into the engine?
Old May 6, 2009 | 09:56 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Is there oil at the exhaust pipe? Curious what it could be.
Old May 6, 2009 | 10:30 AM
Sandblaster01
Rotella T 15w-40 is the oil. I forgot the part where the exhaust is white and a lot of it on acceleration. The exhaust is all the time. The pinging only happens after it gets up to temperature.
Old May 6, 2009 | 12:39 PM
clux's Avatar
clux
Could be a bad injector. Has your Check Engine light come on?
Old May 6, 2009 | 12:49 PM
CampSpringsJohn
White smoke is usually unburned fuel or water. Oil would have a bluish tint to it, and a very distinctive smell. As far as that goes, antifreeze also has a distinct smell coming out of the exhaust.
Old May 6, 2009 | 03:10 PM
Sandblaster01
No engine light has come on. The smoke smells very much like a petroleum base to it. Very heavy alcahol smell.
Old May 6, 2009 | 03:24 PM
superduty4x4's Avatar
superduty4x4
Could be the turbo seals went caput and now you're spitting oil out the exhaust?
Old May 6, 2009 | 03:41 PM
Izzy351's Avatar
Izzy351
Time for a buzz test/CCT I think...
Old May 6, 2009 | 05:24 PM
Sandblaster01
OK, like I said at the beginning, I am a 'shouldn't-be' mechanic.
What do you mean by a buzz test/CCT?
Old May 6, 2009 | 05:35 PM
superduty4x4
A buzz test is a test to make sure the injectors are working okay. CCT is a cylinder contribution test and I can't remember why its helpful right now
Old May 6, 2009 | 05:46 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The buzz test simply tests the ELECTRICAL portion of the IDM to injector solenoid winding to make sure that there are no circuit problems. Internal injector problems will not show up on this test.
The cylinder contribution test will measure the camshaft rotational velocity differences between each injector by disabling one injector at a time and finding out which cylinders contribute equally or insufficiently to engine operation.
