1978 - 1996 Big Bronco
conversion kit
Old May 5, 2009 | 04:36 PM
josh33's Avatar
josh33
conversion kit
i have a 1995 ford bronco 5.8l. and my automatic hubs suck so i am putting in manual hubs, and i have seen this thing called a transfer case conversion kit. would i need one for my truck? if so which one. thanks
-josh
p.s.- how do i get stripped bolts out of my drive shaft going into the bar coming out of my diff.? idk what to do.
Old May 5, 2009 | 04:58 PM
johnboy427's Avatar
johnboy427
On a 95 you should have the six bolt hubs and not need any kind of conversion kit, I did this same swap on my 89 and the manual hubs when right on in place of the autos.
-Johnboy
Old May 5, 2009 | 05:04 PM
alxsnmr's Avatar
alxsnmr
Transfer case conversion for what? You can easily convert a electric shifted transfer case to a manual by swapping cases otherwise the transfer case that came with the truck is decent enough unless you want a geared transfer case then there are other options. Not sure what is ment by conversion.
For stripped bolts into the rear axle? Did you not use a 12-point 12 mm wrench to loosen the bolts? If you rounded off the heads of the bolts holding the rear drive shaft to the axle input flange, you are looking at drilling, grinding the heads off, or hot-wrenching them off.
Old May 5, 2009 | 05:18 PM
johnboy427's Avatar
johnboy427
I think he was looking at the conversion for the old full time cases and yeah he doesn't need that. The bolts on my broncos drive shaft were 12pt, but I would try the heat for sure and let them soak for a while in a good penetrating oil. Oh yeah and be mindful of fuel tanks and lines when heating stuff underneath your truck.
-Johnboy
Old May 6, 2009 | 01:56 PM
McLeod's Avatar
McLeod
Originally Posted by johnboy427
On a 95 you should have the six bolt hubs and not need any kind of conversion kit, -Johnboy
My '95 has 3 bolt hubs.
3 bolt hubs need to convert to standard spindle nuts in order to go manual hub.
The 5 bolt (not 6) hub doesn't need a spindle nut conversion kit.
Old May 18, 2009 | 01:20 PM
josh33's Avatar
josh33
i have 3 bolt hub to. so if i get warn locking hubs, and they have 6 bolts i will have to get the spindle nut kit? where could i find a 5 bolt hub?
Old May 18, 2009 | 01:32 PM
McLeod's Avatar
McLeod
3 bolt and 5 bolt is refering to the auto hubs.
3 bolt auto hubs being converted to manual hubs will need to convert to the different spindle nut configuration.
5 bolt auto hubs shouldn't need to convert.
How many screws the new manual hubs have is irrelevant in regards to the spindle nut configuration.
If you have 3 bolt auto hubs, you need to convert. You need this: (Nuts are not shown in pic)You could save a few bucks by going to NAPA or the wrecking yard and buying the correct pieces a la carte over buying a "conversion kit". It looks as if they charge a $5 premium for the "kit" price. Your choice.
mudslinging79
May 6, 2014 09:33 PM
Josh88Ford
Jun 5, 2013 08:59 AM
josh33
New Member Introductions
May 5, 2009 02:46 PM
82MustangGT
Jul 12, 2007 08:34 PM
countryboy4_1qt
Jan 31, 2007 04:35 PM
