1978 - 1996 Big Bronco
Front end receiver hitch
Old Apr 29, 2009 | 09:40 PM
Skeetman's Avatar
Skeetman
Gents:
Anyone know where I can find a fairly inexpensive front end receiver hitch for my 1995 stock full size Bronco (351 Windsor)? All I will use it for is to move my travel trailer into my garage. The only one I can find online is a $300 Warn receiver hitch that the Warn fellows tell me is really overkill for my purpose. I've looked on the Draw-Tite, Reese and Valley websites and they don't seem to make any that supposedly fit. Any suggestions?
Thanks,
Skeetman
Old Apr 29, 2009 | 10:44 PM
rudedogii's Avatar
rudedogii
Try "Reese" 1(800) 556-7885 or try NorthernTool.com and search "Reese hitch".
Old Apr 29, 2009 | 11:31 PM
greystreak92's Avatar
greystreak92
Curt Manufacturing P/N 31026
If you are looking this is the one manufacturer that I KNOW makes a front receiver for 92-96 F-series trucks. 31026 is the part number for it.
Old Apr 30, 2009 | 10:14 AM
Skeetman's Avatar
Skeetman
Rudedoggi & Greystreak 92:
Thanks for the leads - spoke to the folks at Curt, Valley, Northern Tool and Reese - all are unaware of any front hitches for 95 Bronco - folks at Valley told me front end hitches are relatively new and no manufacturers have yet begun to design them for a lot of the older vehicles - don't know if accurate or not - but, still can't find one for 95 Bronco - may have to fabricate my own. Thanks again.
Skeetman
Old Apr 30, 2009 | 07:06 PM
big bad 79 bronco's Avatar
big bad 79 bronco
why dont u just back it in the garage
Old Apr 30, 2009 | 09:19 PM
Skeetman's Avatar
Skeetman
Big Bad:
Good question. The answer is because I have about 2" clearance on each side with one side blind - impossible to back in without another set of eyes. Front end hitch is the best solution.
Skeetman
Old May 1, 2009 | 09:12 AM
lostinfords's Avatar
lostinfords
this is a cheap way out...but uhaul used to sell a clamp on style for the steel rear bumpers..I would not personally tow anything w/ the set up but it would be ideal to clamp on to set the trailer into the garage.
I used to use my wheel horse garden tractor for the space limited access positions, you should've seen the looks I got moving my 21' boat and then the 19' travel trailer.
Old May 1, 2009 | 11:04 AM
Kemicalburns's Avatar
Kemicalburns
i would drive around to some various fabrication/welding shops and have someone build you one. i bet you will find it reasonable price wise and you can get it to fit better and perhaps be more hidden.
Old May 1, 2009 | 01:40 PM
McLeod's Avatar
McLeod
Check with a snow plow dealer. Some of the low end snow plows utilize a receiver hitch.
Old May 4, 2009 | 07:19 PM
Skeetman's Avatar
Skeetman
Lost/Kemical/McLeod:
Thanks for the info - Think I will try getting a receiver extension welded onto frame just under front bumper.
Skeetman
Old May 5, 2009 | 11:18 AM
Kemicalburns
I would have one welded so it mounts between the frame horns. this will be very strong and could later be used for a winch plate location for you. it would also be hidden behind your license plate for a clean look and not be hanging down
Old May 11, 2009 | 12:05 PM
DerekVS's Avatar
DerekVS
Bronco Front Receiver Hitch
Originally Posted by Skeetman
Gents:
Thanks,
Skeetman
I had the same problem -- couldn't find one anywhere. I finally broke down and got the Warn that you were talking about.
I think I paid around $230 for it (3 years ago) and it bolted right up to my '94 Bronco's frame (I had to cut out a 2.5" square in my plastic air dam). It sticks out enough to where I was able to drill a second hole in one side for my Draw-Tite J-pin to keep my T-bar from bouncing around while driving. It works great and is very solid. It even came with a thick Warn-logo rubber insert for when it's not in use. Sometimes the money is worth the convenience of getting something that works right out of the box.
At the same time, if all you're doing is moving your trailer into your garage, Harbor Freight has a nice trailer dolley with pneumatic wheels and a 2" ball hitch for doing just that!
Old May 18, 2009 | 03:59 PM
JBandit03's Avatar
JBandit03
'03 Wrangler Hitch
You can try a rear receiver hitch for an '03 Jeep Wrangler. A friend of mine has one on the front of his '78 F150. Just had to drill two holes I believe, and put some washers between the hitch and the frame for the front bolts. Ill get some pictures from under the truck this weekend.
Old May 18, 2009 | 07:38 PM
Skeetman's Avatar
Skeetman
Bandit:
Many thanks. Wow, that '78 brings back memories - had a silver one back in the day.
Skeetman
pancake
All Things Towing
Dec 29, 2016 10:50 PM
MarkyB98
All Things Towing
20
Oct 28, 2016 06:15 AM
slewis95407
Aug 14, 2016 02:12 PM
RogueSpear2023
Aug 19, 2007 08:53 PM
AbramsM1
Nov 1, 2004 07:45 PM
