frame width
Old May 4, 2009 | 05:33 PM
69crewcab's Avatar
69crewcab
frame width
DOes anyone know the frame width (from outside frame rail to outsie frame rail) on an 87-91 F-350 4x4??
thanks
Old May 4, 2009 | 06:44 PM
hawgystyle's Avatar
hawgystyle
Width 79.0 inches
go to kbb.com, they have almost every specs you need for trucks or cars
Old May 4, 2009 | 06:51 PM
69crewcab's Avatar
69crewcab
hmmm
that would make it over a 6ft wide frame. i cant see that..
should be something like in the 30+ inch range
Old May 4, 2009 | 06:56 PM
hawgystyle's Avatar
hawgystyle
oh my bad i gave u the entire width, ill check for you again
Old May 4, 2009 | 07:00 PM
69crewcab's Avatar
69crewcab
i looked on kbb weere are you findin it?
Old May 4, 2009 | 07:05 PM
hawgystyle's Avatar
hawgystyle
im searching your truck and then looking that the specs
69crewcab's Avatar
69crewcab
where is that on kbb?
Old May 4, 2009 | 07:08 PM
hawgystyle's Avatar
hawgystyle
you have to go to the used cars section then fill in the description of your vehicle, then when it gets to the page that tells you how much it costs, theirs a button on the left hand of the page that says specifications and after that you click on technical specs
Old May 4, 2009 | 07:10 PM
hawgystyle's Avatar
hawgystyle
and ive searched and your width your lookin for aint there sorry
Old May 4, 2009 | 07:12 PM
69crewcab's Avatar
69crewcab
yea i too found that area, they give body width and height no frame info
Old May 4, 2009 | 07:15 PM
hawgystyle's Avatar
hawgystyle
yea, u can always go measure ur truck with a tape measure and do it that way
Old May 4, 2009 | 08:02 PM
Eddiec1564's Avatar
Eddiec1564
I recall 42" or 47" from outside frame to outside frame. Was in the process of swapping a
HD D70 axle into a 87 F150 frame for a woods truck but didn't due to $$$
Old May 4, 2009 | 08:05 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
I believe it 41"
How I know because I have 2 snow plow mounts for that years it is 41" after 1992 it 40"
Old May 5, 2009 | 03:36 PM
Eddiec1564's Avatar
Eddiec1564
Ok, right above the rear axle, the frame is 38" wide from outside to outside, 42" from spring mount inner edge to same on rear axle.
Did not mesure the front as I had to fight off some fire ants.....
airharley
Jan 4, 2025 04:07 PM
Earnie Rosenow
Nov 10, 2016 11:40 AM
kkubina
Jul 3, 2015 01:06 PM
Andy1966
Sep 18, 2014 07:30 PM
4motion
Jan 22, 2003 06:46 PM
