frame rail width?
Old Jul 1, 2002 | 10:55 AM
airharley's Avatar
airharley
frame rail width?
Anyone know the distance between the frame rails and what year cross member will interchange? I want to lower my engine in the bay and have a beefy cross member vise the aftermarket universal mount. Thanks.
Old Jul 2, 2002 | 11:13 AM
Rosati's Avatar
Rosati
frame rail width?
I believe the outside dimension is 39 inches but I will double check as soon as I get it back from the sandblasters.
Old Jul 2, 2002 | 12:35 PM
airharley's Avatar
airharley
frame rail width?
Thanks Krosati. I am also looking for the inner width. I think I may be able to use the rear crossmember from the old set up "IF" it dips down low enough to clear the oil pan with slight mods. What do you think the chances are for that?
Old Jul 2, 2002 | 05:00 PM
Rosati's Avatar
Rosati
frame rail width?
Chances are good since you will need to box the framerails anyway. You could pick up a 1/4" or so depending on metal thickness and position against the rails.
My crossmember as flat and only falls about 1" below the frame rails. With the double sump pan, the engine should sit right between the rails.
Old Jul 2, 2002 | 07:50 PM
CustomCab4x4's Avatar
CustomCab4x4
frame rail width?
[updated:LAST EDITED ON 02-Jul-02 AT 08:52 PM (EST)]I'm pretty sure the inside is a shade under 34". (seems like it was 33 1/2") The outside IS 34". At least that's what my 64's was. I had a universal engine crossmember in mine when I had the 302 in it. Worked great. It's the same one that Trans-dapt makes and is sold by several places.
Later,
Old Jul 2, 2002 | 08:45 PM
Rosati's Avatar
Rosati
frame rail width?
Phil is right, it is 34" to the outside.
If you box the frame and weld the member to the bottom of the frame, you can duplicate the Fatman type.
If you are planning on welding or bolting it in between the frame rails and not boxing, you will get a lot of frame tweaking. When I get the frame back, I'll take couple of shots and email them to you.
Old Jul 3, 2002 | 06:57 AM
airharley's Avatar
airharley
frame rail width?
Thanks guys. I was talking to one of thguys around here and he suggested a place to get some plate steel to box my frame at. I was thinking of going with 6" U channel steel but he tried that once and really fubar'd his frame. So I will wait until I get a pic or 2 to see what other options are out there.
Old Jul 3, 2002 | 07:44 AM
mtangler's Avatar
mtangler
frame rail width?
Old Jan 3, 2025 | 04:05 PM
Ford's only las vegas's Avatar
4wd Low
Inside frame dimensions on a 2000 f150
I need the inside dimensions for my 2000 f150 at the gearbox i spread it out with a porta power i have it to 30inchs now but don't know if I can go any more or not so I would appreciate if anyone has the inside dimensions please
Old Jan 4, 2025 | 04:07 PM
g4g2g7's Avatar
g4g2g7
you posed your question in the 1961-1966 forum…you’re more likely to get a response in the 1997-2003 F-150 forum.
664x4drvr
Jul 19, 2017 08:43 AM
56panelford
Jun 9, 2015 09:56 AM
sdetweil
Feb 14, 2012 01:09 PM
turnrjr
Nov 25, 2010 04:33 PM
FordF350Baby
Apr 14, 2009 07:44 PM
