Truck running cold?
Old 05-04-2009, 09:49 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Truck running cold?
Ran down to the big city yesterday to pick up some stuff for the truck (bought a door shell for $250 from one guy and sway bar end link bushings and a stabilizer from another for $30, thanks Craigslist!) and noticed that while running at 65-70mph my pyro was only showing 450-500 degrees. DP Tuner set to 100 perf, truck is running fine. Any ideas?
Old 05-04-2009, 09:57 AM
Pocket's Avatar
Pocket
Pocket is offline
I sounds good to me.
Old 05-04-2009, 10:04 AM
strokersace's Avatar
strokersace
strokersace is offline
Cruisin on the flat that sounds pretty good. I usually run a little higher than that due to the 4.10 and running a higher rpm at that speed.
Good find on the goodies! The stabilizer that I pulled off isn't in as good of shape as I thought. Still got the trailer plug when you're ready.
Old 05-04-2009, 10:09 AM
SuperDoodie's Avatar
SuperDoodie
SuperDoodie is offline
What temps did you normally see? I would expect to see them about 100* hotter.
Old 05-04-2009, 10:13 AM
superduty4x4
Yahtzee... normally running at 65 I see about 600-650.
Ryan- don't give up on me, if I hadn't found the good deal on this door I'd be sending a check your way
Old 05-04-2009, 10:17 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
I'm usually around 600-700 at 65-70 mph.
Old 05-04-2009, 10:26 AM
strokersace
No worries man.
That's where I normally run.
Old 05-04-2009, 11:59 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I run about 450-500 at 60-65. Maybe 500-600 at 70ish. On flats, it gets close to 500 at 70 for me, but I have a van turbo -- it should be lower. Was it raining or anything unusual to make the intercooler work better??
Old 05-04-2009, 12:07 PM
03_PSD's Avatar
03_PSD
03_PSD is offline
I got a question for everyone: if i'm cruising at 65 running approx. 3-4 lbs. boost and then, hit a hill good enough to make you push 7-10 lbs. boost, my egts will be 900-1000. Is this normal?
Old 05-04-2009, 12:20 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Yes, that sounds right -- no downshift, correct?
Old 05-04-2009, 12:36 PM
superduty4x4
It was cool and cloudy, not raining, but even driving in the rain and in colder weather I've never noticed the EGT's quite that low while cruising. Could have just been a fluke, but even in the afternoon when the sun came out and the weather was nicer the EGT's stayed the same. I figure I'll just keep an eye on it and see what shakes out.
Old 05-04-2009, 12:57 PM
03_PSD's Avatar
03_PSD
03_PSD is offline
No downshifting, cruse on.
Sorry about the hyjack!!!!
