Truck running cold?
Ran down to the big city yesterday to pick up some stuff for the truck (bought a door shell for $250 from one guy and sway bar end link bushings and a stabilizer from another for $30, thanks Craigslist!) and noticed that while running at 65-70mph my pyro was only showing 450-500 degrees. DP Tuner set to 100 perf, truck is running fine. Any ideas?
I sounds good to me.
Cruisin on the flat that sounds pretty good. I usually run a little higher than that due to the 4.10 and running a higher rpm at that speed.
Good find on the goodies! The stabilizer that I pulled off isn't in as good of shape as I thought. Still got the trailer plug when you're ready. |
What temps did you normally see? I would expect to see them about 100* hotter.
Originally Posted by SuperDoodie
(Post 7461638)
Ryan- don't give up on me, if I hadn't found the good deal on this door I'd be sending a check your way :D |
I'm usually around 600-700 at 65-70 mph.
Originally Posted by superduty4x4
(Post 7461652)
Yahtzee... normally running at 65 I see about 600-650.
Originally Posted by 03_PSD
(Post 7461658)
I run about 450-500 at 60-65. Maybe 500-600 at 70ish. On flats, it gets close to 500 at 70 for me, but I have a van turbo -- it should be lower. Was it raining or anything unusual to make the intercooler work better??
I got a question for everyone: if i'm cruising at 65 running approx. 3-4 lbs. boost and then, hit a hill good enough to make you push 7-10 lbs. boost, my egts will be 900-1000. Is this normal?
Yes, that sounds right -- no downshift, correct?
Originally Posted by Izzy351
(Post 7461952)
(Post 7462031)
Sorry about the hyjack!!!! |
